Hi all,
Just an update for "the next guy" who might stumble across this thread; my jack ceased working and it has taken me time to learn the ins and outs of the
12v power distribution panel. Last time I checked in, I was trying to figure out which breaker was blown. Here is what I figured out:
a) I needed to put the neutral end of my tester on the big white bus bar that held the negative cables from the batteries and then put the probe end on the side of the breaker where power would come out (i.e. the side with the wire leading to the equipment); I know this will be old stuff to many but when you have not done it, not always obvious; I was using one of those probe testers that is like a screw driver with a pointy end that has a light bulb in the handle. If there is power, the handle lights up.
b) once I figured out that only one breaker did not have power on the "load" side of the breaker, I called the dealership to see how to take out the breaker; while I was waiting for them to call back (the parts person did not know), I decided to just try myself; I thought I would just take the nut off of both sides of the breaker (I highlighted them in the picture) as I thought maybe that would help get the breaker out.
- but while starting on that, I noticed that this breaker did indeed have a little button on top of it...so I pressed it and the breaker was reset; eureka! I had not noticed this before because I had been trying to find a reset on some of the other breakers and when they are working right, they do not protrude
c) also found out that both the panel cover are wrong as to which breaker the jack is on; the panel says it should be on post #6 on the bottom (there is no post 6) and the manual says it should be on post #5 (there is a post 5 but no wire running from it); the jack turned out to be on post #4. It has 2 wires attached to the it (the load side that is) so I am wondering if someone already blew a breaker and instead of replacing it, they just put two circuits on one breaker (or maybe AS does that anyhow). So I have relabelled my book and the panel stickers for now (with masking tape as I might fix this us). Also, I wrote down that the reset button for the top row of breakers is on the bottom (the ones that I was checking to no avail) and the reset button for the bottom row is on the top.
So my last question is, if I actually test post 5 and that breaker is not working, how does one get these breakers out of the panel? Do you have to remove the nuts from both posts and then maybe the breaker comes off somehow?
Also, that big red wire with the blue connector on it - that is the hot wire coming from the battery bus cable back by the converter. It is the "feed" to the distribution panel.
Thanks all.
Albert
