Old 01-14-2025, 01:28 PM   #1
2021 22' Caravel
WAMEGO , KS
Power in camper with batteries not installed
Hello have an odd one. New owner of a 2022 caravel 22fb. Stored batteries inside for winter. Has factory solar option. Turned control panel to off. Went to check in camper today. Battery switch was illuminated, radio was powered on and thermostat was powered. Will the solar panel power these systems without any batteries? I went as far as wrapping the positive sides of the terminals with electrical tape. Curious how this is possible! Thank you.
eric990 is offline   Reply With Quote
Old 01-14-2025, 01:41 PM   #2
JeffKim's Avatar
2023 25' Globetrotter
2021 16' Bambi
Forest Lake , Minnesota
Yes, it will. It's one reason to install a solar disconnect switch especially when working on the electrical system so not to fry something. The disconnect switch will disable most DC loads except parasitic ones like the CO detector and the inverter standby.
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
JeffKim is online now   Reply With Quote
Old 01-14-2025, 04:07 PM   #3
2021 22' Caravel
WAMEGO , KS
Thank you so much. I was curious. I swore I turned the victron controller off but figured it still was powering the system. I will look into the solar disconnect. Do you have any recommendations?
Old 01-14-2025, 04:22 PM   #4
JeffKim's Avatar
2021 16' Bambi
I have a two pole breaker like this one, that is wired before the charger, so somewhere in the rat's nest where the charger is. Supposedly according to "code" the switch or breaker is supposed to be two poles, but I think the consensus is that only one is really necessary. So, any old breaker or switch will do. I like this type for single wire.
I didn't think about it but I replaced the standard Victron Blue controller with a Victron Smart 100|30, so I can just turn the controller off via Bluetooth if I wanted. I recommend making this upgrade regardless, it makes monitoring a lot simpler.
2017 Audi Q7 3.0T
WBCCI 6343
Old 01-14-2025, 04:56 PM   #5
2021 22' Caravel
WAMEGO , KS
Im sorry I’m on mobile I can’t see what you attached. I will hop on the laptop
Old 01-15-2025, 01:04 AM   #6
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
The solar systems are designed to work WITH BATTERIES in place. It is not a good idea to run the solar without a battery.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 01-15-2025, 07:15 AM   #7
2021 22' Caravel
WAMEGO , KS
It wasn’t my intent to run the solar system without batteries. I used the controller to turn the system off thinking that’s what I needed to do. I removed the batteries so they weren’t exposed to the cold weather and currently have them on maintainers.
Old 01-15-2025, 07:29 AM   #8
2022 33' Classic
Chesapeake , Virginia
That breaker is what Nate of Explorist Life on Youtube used in his setup. He has a good video covering that installation. I did the same thing. It was a bear to install in my front storage compartment, though.
BGClassic is offline   Reply With Quote
Old 01-15-2025, 08:19 AM   #9
2021 22' Caravel
WAMEGO , KS
Thank you. I’m guessing the remote dongle option takes away the communication to the onboard control panel?
Old 01-15-2025, 09:20 AM   #10
JeffKim's Avatar
2021 16' Bambi
Yes, with the Smart it also doesn't take away the plug in to the monitor.
2017 Audi Q7 3.0T
WBCCI 6343
Old 01-15-2025, 01:05 PM   #11
2021 22' Caravel
WAMEGO , KS
Sorry I am misunderstanding. Can I still use the control panel in the bathroom or when I get the dongle it takes away communication to the onboard panel? Thanks again
Old 01-15-2025, 02:31 PM   #12
JeffKim's Avatar
2021 16' Bambi
If you use the dongle on the Victron Blue which makes it Bluetooth you lose the connection to the panel.
2017 Audi Q7 3.0T
WBCCI 6343
Old 01-15-2025, 03:29 PM   #13
2021 22' Caravel
WAMEGO , KS
That’s what I figured. Appreciate it!
Old 01-18-2025, 11:03 PM   #14
Still Learning
2013 25' International
Benzonia , Michigan
Are your batteries lithium? If they were fully charged when you brought them inside they do not need a "maintainer." They loose very little charge. Mine are outside in cold northern Michigan still sitting at 100% charge since fall. Fully disconnected system with separate disconnect switches for the solar, inverter/charger and battery parts of the system. Cold does not hurt them, CHARGING them in cold temps will kill them.
trailerKat is offline   Reply With Quote
Old 01-18-2025, 11:12 PM   #15
Still Learning
Benzonia , Michigan
We have the Victron BMV-712 with bluetooth and the OEM monitor panel on the wall still works though we never use it to monitor the electrics, only the fresh grey black tanks. Maybe it depends on how your installer wired things up?
Old 01-19-2025, 07:42 AM   #16
2021 22' Caravel
WAMEGO , KS
I have the factory lifeline agm batteries. Not lithium.
Old 01-19-2025, 07:44 AM   #17
2021 22' Caravel
WAMEGO , KS
It’s all the factory solar system. I need to find out which monitor panel it is. It’s the victron 150-35 mppt controller.
Lithium batteries drained after dealer installed in 23 Caravel Fultsie Electrical - Systems, Generators, Batteries & Solar 11 04-16-2023 04:49 PM
Both Fantastic Fans not working after batteries installed from winter storage Melucy2airs Our Community 14 03-27-2020 08:24 AM
Help! "Installed" Shunt... now batteries won't charge :) thiel Electrical - Systems, Generators, Batteries & Solar 15 04-30-2018 02:20 PM
Is this a factory installed solar panel ? I think it's factory installed and ... JacobMerridy Electrical - Systems, Generators, Batteries & Solar 1 01-14-2017 10:23 AM
30 Amp Power w/o House Batteries Installed Airrayd Electrical - Systems, Generators, Batteries & Solar 4 11-29-2004 01:49 PM
