Old 07-08-2018, 11:43 AM   #21
journeydog's Avatar
2018 28' Tommy Bahama
Silver City , New Mexico
Many of the above comments are very helpful. The following does not discuss your 'E7' code display but, the cure could be within.
I also have a Dometic thermostat and suffered a couple of nights in a cold A/C induced climate - when it wasn't needed. (The A/C would come bursting alive in the middle of the night.) This was during the maiden/shakedown voyage, so I was pretty clueless - and I may have retained that characteristic. I invented a lot of new cuss words until I discovered that the Dometic controller indicated (in very small lettering) that the current "time-of-day" was programmed inappropriately (my bad).
Check your t-stat's "time-of-day" - mine was set to 'pm' rather than 'am' - or vice-versa, as it should have been. i.e., 10 in the morning is not 10 'pm'. After I corrected it, all was good. (I still have some issues with the thing but, it is definitely not cooling down all night as before.)
"To err is human - to really screw up takes a computer." Duh, the Dometic T-stat is microprocessor-controlled and only does what you tell it to do.
Class A Safari Trek 2830 - SOLD; TC Lance 1010 - SOLD;
TT Arctic Fox 30U - SOLD; TT Forest River Mini - SOLD;
Class B+ Pleasure Way P
ursuit - FS; $$$$ - GONE
If it ain't broke I can break it
A dime still makes a pretty good screwdriver
journeydog is offline   Reply With Quote
Old 10-23-2021, 11:58 AM   #22
RivetzCarlAS's Avatar
2022 25' International
Boca Raton , Florida
I too have that issue with error code E7. Brand new 2022 25 Int’l. Trying to run only one ac. Plugged into the 20 amp connection of a 7000 watt generator. Checked all connections at every source multiple times. Reset thermostat hard reset. Unplugged cord from rig and RE plugged. Unplugged at source of power as well as reset. Again and again I keep getting e7 error. I also have soft starts on both acs. Still no power. Just error message. All breakers and fuses checked and are
Ok.
What gives ??
The Rivetz Carlton
2022 25' Int'l Covid-19 Edition GT Zipdee Wannabe
Florida Flats
Let's Pet Dogs Together
(not a euphemism)
RivetzCarlAS is offline   Reply With Quote
Dometic RM3762 Error code E1 help Airstream01 Refrigerators 20 01-28-2019 11:01 AM
Dometic refrigerator error code e0 lgring 2011 - 2015 International 0 02-12-2016 07:55 PM
Error Code 299-Loss of Power milkfish888 Sprinter and B-van Forum 12 07-02-2014 05:57 PM
Onan gold5000, error code 14 kmamedia Land Yacht/Legacy Motorhomes 0 11-10-2008 11:06 AM
Error Code 127 in Classifieds 66Overlander Forum Admin, News and Member Account Info 3 11-30-2004 04:53 PM
