Old 07-30-2021, 03:36 PM   #1
Aledo , Texas
Possible dead breaker
We have a 2005 19' Bambi, and just got it back from the shop to get a sway control ball put on and break/axle check on it. It's been gone about 2 weeks and when I got it back home and plugged in, I noticed the fridge wasn't working. Breakers were all on, I went and ahead and flipped them all, checked fuses, but then I tried to push the "test" button on the GFCI 20 amp breaker and it would not trip. Then I noticed that its seems that circuit is dead, no power to vent fan, light, tank monitoring, water pump. The circuit it labeled "GFI-bath-refer-galley-outside" so it seems possible its a bad breaker? It switches on and off, but does not trip when the test button is pushed. I've seen breakers and GFCI receptacles go bad before, so I am thinking this must be it. I have an electrician coming Monday, as I'm not really comfortable replacing it myself. Any other thoughts on possible issues? Thanks!
TXtugboat is offline   Reply With Quote
Old 07-30-2021, 04:53 PM   #2
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Can you confirm that your trailers 12VDC systems are also working?
The fridge needs 12VDC as the control system power.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is offline   Reply With Quote
Old 07-30-2021, 05:22 PM   #3
ITSNO60's Avatar
Tucson , AZ
As an electrician one thing I always tell people is when you reset a breaker that has tripped you must first force the handle hard to "OFF", if you don't do this it won't latch "ON"
Brian
ITSNO60 is offline   Reply With Quote
Old 07-30-2021, 05:33 PM   #4
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Yes, it's perfectly possible the breaker broke. It happens. Let the pro sort it out on Monday.
Old 07-30-2021, 06:43 PM   #5
Aledo , Texas
Seems like everything else is working fine. Like itís Just that circuit that I can tell...
Old 07-30-2021, 06:45 PM   #6
Aledo , Texas
I was actually a home inspector for 5 years, so I have some experience throwing breakers (and homeowner for many more on an old house) so, yeah itís definitely been hard off and on.
Old 07-30-2021, 06:54 PM   #7
ITSNO60's Avatar
Tucson , AZ
Sounds good. I can't tell you how many service calls we had where we tried to explain this over the phone and the customer insisted they did it, then we'd get there and reset it in two seconds.
Brian
Old 07-30-2021, 07:03 PM   #8
eubank's Avatar
Airstream - Other
Bosque Farms , New Mexico
Happened to me. It was a weak GFI breaker in the 2016 AI, always popping after about five minutes of service. Finally, I pulled it out, took it to the hardware store, and got a new one. Been working just fine since.
Lynn
ACI Big Red Number 21043
eubank is online now   Reply With Quote
Old 07-30-2021, 07:14 PM   #9
Aledo , Texas
Oh I can imagine!! Thanks for the replies!
Old 07-30-2021, 07:43 PM   #10
2017 19' International
Tallahassee , Florida
I had my refrigerator stop working after about a year and half, and it turned out to be a bad circuit breaker.
WhereStream is offline   Reply With Quote
Old 08-02-2021, 01:37 PM   #11
Aledo , Texas
New breaker installed and still no power at fridge and vent fan/light! Any ideas?
Old 08-02-2021, 02:03 PM   #12
ITSNO60's Avatar
Tucson , AZ
Where is the power? Did you test at the breaker terminal screw? If no power there check bus, bus jumper. If there is power at breaker terminal screw work the other direction, most likely came apart in a receptacle. Does the new GFCI breaker trip on test? If not, it is not receiving power, check bus jumper.
Note on edit:
It's a bit confusing that you say fridge and vent fan, are you talking about the 120 volt power or the 12 volt power?
Brian
Old 08-02-2021, 02:17 PM   #13
ITSNO60's Avatar
Tucson , AZ
I don't mean to offend you but the fact that you replaced a $50 breaker and it wasn't the problem suggests you are working by trial and error which is not a good way to do electrical troubleshooting. If you do not have the equipment and knowledge to follow the power I suggest you wait for the electrician.
If it's your 12 volt did you check not only the 12 volt fuses but the 12 volt circuit breakers?
Brian
Old 08-02-2021, 03:13 PM   #14
eubank's Avatar
Airstream - Other
Ah, vent fan/light? Those are 12 volt, aren't they?
Have to agree that you might want to get yourself a certified RV type to work on your rig for you.
Lynn
Old 08-02-2021, 03:30 PM   #15
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
You quite possibly have a 12 volt breaker that needs to be reset. Check this first!! No 12 volt, fridge no work!
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34' 1987 Limited 34'
1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 08-02-2021, 05:19 PM   #16
Aledo , Texas
Well it wasn’t a breaker, but it was a fuse! I found the diagram and pulled that specific fuse and sure enough it’s blown. I had checked them by flashlight, but hadn’t pulled them all (FYI, in this model it’s the pink wire 20amp fuse that controls galley, monitoring system, fridge and range vent/light). The breaker needed to be replaced anyway as it was not tripping with the test button, so it’s not money wasted. Now I’ll go buy a few fuses! Thanks for the help and the emphasis on the 12 volt system.
Old 08-03-2021, 06:38 AM   #17
eubank's Avatar
Airstream - Other
Great news that you found the culprit! It's not a shabby idea to get yourself a small box of assorted fuses from a big box store or the hardware. For starters, they're cheaper that way, and you never know when you just might need one.
Lynn
Well it wasnít a breaker, but it was a fuse! I found the diagram and pulled that specific fuse and sure enough itís blown. I had checked them by flashlight, but hadnít pulled them all (FYI, in this model itís the pink wire 20amp fuse that controls galley, monitoring system, fridge and range vent/light). The breaker needed to be replaced anyway as it was not tripping with the test button, so itís not money wasted. Now Iíll go buy a few fuses! Thanks for the help and the emphasis on the 12 volt system.
Possible dead animal in holding tank terricrowe26 Waste Systems, Tanks & Totes 22 12-22-2017 07:36 AM
Possible dead battery 2015 Flying Cloud chekmate99 Batteries, Univolts, Converters & Inverters 54 08-02-2017 05:32 PM
Breaker, Breaker!! Bing-Bing Generators & Solar Power 25 09-24-2013 08:25 PM
breaker breaker project66 Batteries, Univolts, Converters & Inverters 4 05-29-2012 08:37 PM
Dead ...really dead Melody Ranch Batteries, Univolts, Converters & Inverters 17 06-13-2007 12:23 AM
