We're picking up our '23 Intl 25 FBQ (dual AC, 300W solar package) on Wednesday and heading out for a three week trip on Saturday.
When we get back, I'm planning on doing a major swap of components to install either 4x or 6x100Ah LFP batteries.
However, for this first trip, I'm planning to simply remove the AGM batteries and install 2x100Ah LFP batteries.
Am I correct that this is "all" I need to do to swap the batteries with a bone-stock "as it left the factory" setup?
- Enable lithium charging mode on the WFCO converter by swapping the DIP switch from LA to LI (if integrated) or by jumpering the Lithium switch jumper (if deck mounted)
- Change the Victron BlueSolar charge profile to switch position 7 (lithium)
Thanks!
Sources:
https://support.airstream.com/hc/en-...ravel-trailer-
https://www.victronenergy.com/upload..._manual-en.pdf
