I'm redesigning the DC wiring and fusing at the front of my 1986 29'
Sovereign and wanted to understand the merits of a one or two connector umbilical harness. Currently my worn cable and local mice run under the frame and enter the belly pan just behind the center of the front shell. The cable then enters the interior through large hole in the OSB floor just under the
12V circuit breaker panel. Historically I have had problems with both contamination and with wires getting pulled in the umbilical (causing no brakes).
Two connector design Pros:
1) Stored cable - The cable can be stored when not in use, minimizing connector contamination.
2) Removing holes in floor - A 7 pin female receiver could be mounted to the shell wall between the battery boxes. This would remove the need for a hole in the belly pan (assuming I move the ground wires and grounding connectors inside the belly). This also allows for a smaller hole in the floor for brake, brake switch and jack wires.
3) Future replacement – this would greatly simplify future replacement in case I have another problem or go with a longer hitch approach (Hensley / ProPride).
One connector design Pros:
1) Fewer connections = fewer potential problems
The engineer in me says to minimize connections however the two-connection design has its merits.
Cable Type - In addition I was considering either the coiled or cold weather silicon Bargman harness to put less stress on the connections when in use.
Does anyone have poor experience with the two-connector harness approach?
Thanks, Scott
