11-05-2017, 03:49 PM
2019 30' International
Estero
No shore power unless hooked to truck
All,
HELP!! We are heading out on vacation in less than 10 days. We went over to our AS - 2016 Intl 27FB, opened the door and no power on at all. The In UseStore button dead, no lights, no AC, no nothing.
The whole time it was plugged into the power source at our storage unit. 30amps and light was blue at the power connect on the AS and green at the plug. All breakers and fuses are fine.
We plug the tow cable into our truck, and viola! The lights, AC, everything works. After 10 minutes, made sure the battery was set to "In Use" un plug the truck cable, and slowly things fail, no AC, no lights, no nothing again.
Interesting that when it was working while plugged into the truck when I hit "Store" on the battery switch, everything went off?
Solutions????? Does a dead battery kill the entire circuit?
11-05-2017, 05:08 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Your coach batteries are dead....when connected to your TV it's battery supplied the power for the lights etc.
AC= current or air conditioner?
The umbilical to the TV has nothing to do with alternating current,AC.
If you have no AC, you have a converter or AC supply problem.
Plug into a working shore power supply and ck/reset all breakers, with the umbilical connected.
Were you plugged into the TV and shore power at the same time?
Good Luck...
11-05-2017, 06:39 PM
Estero
Thanks for the quick response. The unit is plugged into shore line power, and the Air conditioner, does not run, lights are dim, all breakers reset. I leave it plugged into the shore line electrical and then hook up the tow vehicle connection and everything inside works like new. No issues at all, Air conditioner runs, fridge runs on the Auto mode.
Plugged a charger into the batteries ( which worked from the outside 110 plug on the trailer) and it is showing that the battery is charging. The inisde volt meter is at 8.8
11-05-2017, 06:49 PM
2017 27' Flying Cloud
Fort Worth
Your batteries should be over 12V. Your's are completely depleted.
11-05-2017, 07:30 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
If the battery charger is working from the outside 110 receptacle then the converter is working on the 110AC side, but not charging your house batteries.
8.8v with the external charger connected is not enough, should be at least 14.2v
You may have had surge or brown out. Have the storage shore power & converter tested.
Take the batts out, charge for at least 24hrs, let sit 2hrs & test. NAPA or local Auto parts store should be able to do it.
11-06-2017, 03:40 AM
Estero
So dead batteries impact shore power?
So what you are saying is that the batteries being dead will impact the AC power inside for the AIr Conditioning running?
11-06-2017, 06:31 AM
Livingston
Yep, the AC's need a 12 volt supply as well to run.
Sphere Guy
AIR 50601
11-06-2017, 07:01 AM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
8.8 is essentially a dead batter for AS purposes. If they are new, as Robert suggested pull them and put on a real charger and see if they come back. If they do, I am guessing your converted is bad and not charging.
Rather than secure the same converted I'd spend, and have, a little money and buy one recommended by Randy at Bestconverter.com.
Bud
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
11-06-2017, 07:50 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Yes.....BUT.
Modern converters will supply 120v & 12v with the batteries removed.
All systems should work properly when plugged into shore power with the use/store switch in the 'use' mode.
Confirmed today on our Classic....12v to all systems with no batteries. 14.4v on the monitor.
11-06-2017, 07:52 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
If you put it into the "Store" position while it was stored the batteries were not being charged. I would buy new batteries at this point.
11-06-2017, 09:17 AM
Estero
So the batteries are critical even when plugged into a shore line. I thought that you could run everything without batteries in. Thanks again!
11-06-2017, 09:34 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
You can.
I just confirmed that this morning, two posts up.
As long as the use/store is in the use mode, the 12v system is powered.
11-06-2017, 10:09 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
On my trailer that sits. I disconnect the batteries each spring when I leave. Last year we we used the trailer for a month before I remembered that I had not reconnected the batteries.
11-06-2017, 10:11 AM
2017 25' International
Niagara-on-the-Lake
, ON Canada
Yes, the AC is controlled by the wall thermostat in your coach and the thermostat needs 12 volt power to function. This also applies to your refrigerator on propane and the furnace.
Ray B.
11-06-2017, 10:44 AM
2017 27' International
Agoura Hills
This happened to us and less the breaker is tripped, the converter went bad. If you don't hear the converter running when this would further confirm the converter is bad. Without the converter, the batteries will drain and nothing will run. Solar and hooking to your tow vehicle will charge batteries directly and do not need the converter. This is why after ten minutes or so you have enough battery power to run some items.
11-06-2017, 11:03 AM
2007 25' Safari FB SE
Aiken
, South Carolina
Your house batteries are dead, but probably dead because your converter has failed. Most AS systems (HVAC, fridge, entertainment) require a full 12v to operate.
11-06-2017, 11:47 AM
1976 31' Excella 500
Chappell Hill
My 1976 AS runs everything from shore power with no battery installed and no TV connected.
11-06-2017, 03:14 PM
2015 30' Classic
Sherwood
, Oregon
What tbashin said. My prior AS (2014 Serenity) and current 2015 Classic runs all 110V accessories hooked up to shore power and battery switch in the “store” position. I believe the 12V needed for the thermostat, lights, refrigerator, etc. comes from the power distribution control panel. The batteries should be isolated with the battery switch in the “store” position with only propane and carbon monoxide detectors drawing power from them.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
11-06-2017, 05:28 PM
Framingham
, Massachusetts
Completely different electrics/system in the past 40 yrs. Not a valid comparison.
11-06-2017, 07:09 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Again.... it is valid with our Classic...if use/store is in the USE mode the 12v system is live when on shore power with NO batteries.
