Old 06-17-2021, 11:58 PM   #1
2017 20' Flying Cloud
San diego , California
No power or charge from shore power
Hi there, this is my first post.
I have a 2017 20ft Bambi whose batteries will not charge & has very low power when connected to shore power. The batteries will charge when connected to the tow vehicle. They are nearly brand new batteries.
Our power cable lights up red as if it’s working. We have tried multiple different outlets. Have checked GFCI outlets inside, and switched out fuses. Power switch is set to on.
I read on another thread about a ‘transfer switch’, but couldn’t find detailed information of its whereabouts & whether or not this is something we could switch out ourselves. Or possibly it’s a different issue?
Any input is appreciated..
best,
Tiffany
bambicamps is offline   Reply With Quote
Old 06-18-2021, 07:08 AM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
If none of the 110 outlets work at all when connected to shore power then you have a problem with the 110. Bad transfer switch it the trailer has one. Or broken wire or loose connection in the power cord. It will not charge the batteries if there is no 110. Since your power light is on you are probably getting some 110.
If any of the outlets work and you are getting 110 then the problem is probably in the circuit with the power converter that charges the batteries. No power to it or a faulty converter. Maybe you better put a battery charger on the batteries to keep them from going way down.
you need to find the power converter and test to see it it is getting110 volt input.
I know not a good answer but at least it will bump you question back to the top until someone who knows the newer units sees it
Dometic refrigerator won’t run on shore power& water heater light on when on shore po fotoman1527 General Repair Forum 23 05-03-2022 05:29 PM
Charge Lithium Battery With Shore Power hovr Generators & Solar Power 56 07-24-2020 07:32 AM
Battery will not charge on shore power yldhawg Electrical - Systems, Generators, Batteries & Solar 21 06-06-2019 04:44 AM
Battery doesn't charge without disconnect / reconnect of shore power WineStream Batteries, Univolts, Converters & Inverters 5 03-26-2013 06:32 PM
Full Charge - No Charge! Cracker Batteries, Univolts, Converters & Inverters 2 06-22-2007 02:04 PM
