RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 12-28-2016, 07:54 PM   #1
lesnlearned's Avatar
1973 31' Sovereign
sunnyvale , California
Need to replace the control panel - LP and H20 tank gauges shot
Hi All! Assume this is well covered, but finding information on this is proving challenging via forums search. My '73 sov is nearing completion from a systems/infrastructure perspective. The control panel seems to be caput however. I was thinking of migrating the switches and gauges anyway, but now I have more of an issue.
Where would I go to find modern gauges for my fresh, grey, back and LP. I've found some online and maybe I just buy one of those. How do I know what works for my older model? I'd love to hear that it's all plug and play, but between my AS and '62 Chris Craft, that answer has never been heard.
Any recommendations please fire away!
Mark
lesnlearned is offline   Reply With Quote
Old 12-28-2016, 08:46 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I don't know about plug and play, but if you have access to your tanks, the SeeLevel system gets good reports. They have systems that have everything you want except only one LP indicator so you will have to add a switch to determine which tank it reads. You will have to install their transducers on your tanks, but they stick on from the outside and you can use the existing wiring.
Al
Panel gauges Thomasmg Electrical - Systems, Generators, Batteries & Solar 2 07-07-2015 11:05 AM
'69 Safari control panel gauges Dixie722 Batteries, Univolts, Converters & Inverters 0 03-11-2014 09:13 PM
1974 Control Panel Gauges JimWeilhammer Electrical - Systems, Generators, Batteries & Solar 5 09-12-2012 09:32 AM
Tank monitors, level sensors and/or gauges. BarnacleBill Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 16 09-24-2010 01:09 PM
Filling H20 Tank via Hooked-up Hose Mike76251 Fresh Water Systems 9 03-20-2004 08:39 PM
