Old 08-12-2019, 05:00 PM   #1
Narv's Avatar
2015 30' Classic
Hayward , Wisconsin
Need Help Troubleshooting A Dometic Air Conditioner
My zone 2 (rear) Dometic heat pump won't cool...the zone 1 unit is working fine. I didn't hear the compressor trying to start at all and the unit was pulling 3 amps with only the fan running when the thermostat was calling for cooling. Just previous to this failure, I was starting to suspect that the compressor was continuing to run well beyond the temperature set point; although I never had the chance to prove my suspicions. If the start capacitor is bad, would I hear the compressor trying to start; and would it be pulling more amps trying to start...or not necessarily so? The temperature set point issue has me wondering if the thermostat or control board is involved. Can anyone point me in the right direction for troubleshooting this? Unfortunately, I don't have 30-amp service at home so I'm just at the thinking stage at this point.
Steve
'15 Classic 30 Twin/'11 CC Silverado 2500HD Duramax
Narv is offline   Reply With Quote
Old 08-12-2019, 06:19 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
Typically the thermostat is connected to the zone 1 unit with a cable very much like a modular telephone cord. Another one goes from the zone 1 unit to the zone 2 unit. You should be able to see these cables by removing the interior shrouds. Turn you AC breakers off before removing the shrouds. Disconnect each connector and clean the cable connector and the female connector on the unit with alcohol. Use a Q-tip on the female unit. Often corrosion causes these connectors to malfunction. You could also try a reset on the thermostat.
Al
Al, K5TAN and Missy, N4RGO - WBCCI 1322
2013 Ram 2500 Laramie 4x4 Megacab Cummins
Dometic AC/HeatPump/Furnace Troubleshooting tifspiff9 Electrical - Systems, Generators, Batteries & Solar 0 05-05-2019 02:40 PM
Dometic RM2601 startup/troubleshooting 2002sheds General Repair Forum 8 04-17-2018 10:22 AM
Need help troubleshooting elec / gas water heater polarlyse LP Gas, Piping, Tanks & Regulators 0 08-26-2012 03:04 PM
I need a good source for dometic Air Conditioner parts 0557 Furnaces, Heaters, Fireplaces & Air Conditioning 0 08-18-2004 04:31 PM
