Old 05-03-2024, 02:04 PM   #1
HOLLAND , NY
Monitoring batteries in a new Flying Cloud
I'm trying to verify something that seems foriegn to dealer personel. Have a 2024 Flying Cloud with factory solar. Looking through the system I see a shunt installed in compartment with other components but no wire going into a monitor. Went out with my Victron Connect app. and I'm seeing a Victron Smart Shunt pairing. Nobody has said a word to me about it being there. They tell me I can montitor battery condition through the MPPT montitor which is incorrect. Just trying get verification that Victron Smart shunt is supplied and that someone knows about it.
Also, the max voltage reading I'm seeing with MPPT monitor on float is 13.6 volts. This has me wondering if Victron controller is NOT set to lithium. Anybody with similar experiences?
Forester2 is offline   Reply With Quote
Old 05-03-2024, 02:26 PM   #2
JeffKim's Avatar
2023 25' Globetrotter
2021 16' Bambi
Forest Lake , Minnesota
Did you try connecting to the shunt? The default password is six zeros (something like that). It's probably a new beast to the dealer, the old battery monitor was the voltage meter dial as you indicated. The shunt is far superior, but it doesn't have its own monitor, just your phone. You'll have to make sure it's set for lithium, under batteries. There are a bunch of parameters to set, I think the BB website has a FAQ for this.
The voltage seems right for fully charged lithium batteries. Assuming you're in the sun, if the MPPT is putting out close to zero watts, then likely they are charged. There is a menu system you can check for the charging profile, but it might take some effort. If you can get to the solar controller there is a dial and it should be set to "7" (I'm assuming it's the standard issue Blue Solar 150|35). I'd replace the Blue Solar with a Smart Solar and then you can monitor charging from your phone as well. It's easy then sell the Blue on eBay. Or you can get a dongle for it ($50), but then you lose the MPPT monitor.
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
JeffKim is offline   Reply With Quote
Old 05-03-2024, 04:18 PM   #3
HOLLAND , NY
I did and was connected. Thats how I figured out what I had. Airstream did get back to me and confirm that (very promptly). I was just disheartened nobody kbew about it on my walk through. As people get more educated on solar, lithium, etc., these are features they want to know about. Just wish solar controller was ble tooth as well.
Old 05-03-2024, 05:07 PM   #4
2022 33' Classic
Chesapeake , Virginia
You will read about many others that have had poor dealer walkthrough experiences. Our dealer knew nothing about the Alde. Fortunately, there is a wealth of information on this forum.
Read all the manuals, watch Youtube videos, and read this forum.
BGClassic is offline   Reply With Quote
Old 05-03-2024, 05:29 PM   #5
JeffKim's Avatar
2021 16' Bambi
Yes, they seem to put the same Blue solar controller on every model. They must get a great deal on them in bulk. It's not a whole lot more money for a Smart version and the 150|35 is a lot more than what's required for the solar package.
2017 Audi Q7 3.0T
WBCCI 6343
Old 05-04-2024, 04:37 AM   #6
HOLLAND , NY
I actually have a Smart Solar 100/30 from our old camper I may put in. Not putting any more panels on roof since I carry a 200 watt suitcase panel if I need extra.
Help locating negative battery wire for new Victron BMV shunt gjhathaw Batteries, Univolts, Converters & Inverters 9 07-12-2023 11:58 AM
To Shunt or not to Shunt, Streamside Batteries, Univolts, Converters & Inverters 17 06-06-2023 08:37 AM
Fresh water shunt installed Excella CM Fresh Water Systems 5 01-19-2010 01:13 PM
Anyone out there with ammeter/shunt experience? johnobuttons Lights - Interior & Exterior 2 08-17-2009 12:40 AM
TriMetric 2020/2021 shunt - 100 or 500 amp? ostream Electrical - Systems, Generators, Batteries & Solar 3 11-06-2008 03:37 PM
