05-13-2021, 11:40 AM
2015 28' Flying Cloud
Hoover
Minimum size generator
Have a 2015 28’ FC and was wondering what would be the minimum Watt generator suggested for just basic shore power? No a/c or microwave. Thanks
05-13-2021, 11:43 AM
Sag Harbor
, New York
Welcome to the forum. We have a Yamaha 1000 and run it off the low-pressure propane port. Works fine for keeping the batteries charged, and the fridge cool, but this is about the limit IMO.
https://www.google.com/search?q=Yama...=airforums.com
https://www.airforums.com/forums/f44...hc-188969.html
https://www.ypngg.com/ef1000is.htm
Small/compact and light at 27 lbs. -- very easy to carry, set up, and stow in the tow vehicle. Also a great emergency gen to have at home, running off a standard BBQ propane tank, for storms, hurricanes and so forth. Enough to run a small fridge someplace IMO.
The Generators sub-forum may also be a good place to look IMO: https://www.airforums.com/forums/f448/
Good luck,
05-13-2021, 12:03 PM
2002 25' Safari
Dewey
I use a Honda 1000 when just charging the batteries. Some have reported that larger capacity converters will push the limits of a 1K generator. An electric/gas refrigerator will pull 4 or more amps which only leave you 4 amps for the converter. It you are hitting the limit, keep the refrigerator on Propane.
Richard
05-13-2021, 12:07 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
Depends upon what loads you want to run on "basic" power. The power converter is on all the time and could draw a good bit of power when the batteries are down and you are on generator. I have seem mine at 7 amps draw. Coffepot? hair dryer? Otra did not say what he runs on his 1000 except charging. My guess is that unless there is a special need to have it smaller one of the 2200 watt generators would be near a minimum to charge and make coffee at the same time. I do not really know. I have been carrying and running a Honda 2000 for the last 12 years. It is a bit heavy for me now but I hate to give it and the extra power up to go smaller.
05-13-2021, 12:17 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
Greetings from the Florida Panhandle
We have found that a Honda 2000 can handle the entire trailer without using the air conditioner or heat pump.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
05-13-2021, 01:34 PM
Hoover
Thanks. That’s what I have.
05-13-2021, 01:58 PM
2018 30' Flying Cloud
Springfield
, Ohio
No smaller than 2000 Watts in my opinion.
2018 Flying Cloud 30RB + 2020 Silverado 2500HD Duramax/Allison
05-14-2021, 09:26 AM
2021 16' Caravel
Smithville
, Tn
No smaller than 2000 and a 2200i from Honda will cover everything including an a/c with smart start.
05-14-2021, 09:51 AM
Alamo Heights
I don't have a good feel for the footprint difference between the 1kw and 2kw inverter generators, but the 2kw Honda is only about 18 lb heavier and the "street price" is only about 15% more for more than double the peak output (for Honda, e.g., the little one is still 1000w but the next size up is 2200w)
— David
05-14-2021, 11:37 AM
Sag Harbor
, New York
The 1000 is a very good tool for a specific job [per Post #2] IMO.
One can never have "too many tools" . . .
Need 2200 watts?
Buy the 2000 also!
Choose your tools for the trip at hand, just like building a house. Take some with you . . . leave some home . . . KISS . . . avoid analysis paralysis.
05-14-2021, 11:53 AM
Tampa
Here's the problem. That 28' has lots of creature comforts. One day you'll be in a beautiful spot, but the outside temperature will be 90 deg. You'll be thinking, "I wish I had a bigger generator."
I have a 3000, but look with envy at the 7000.
05-15-2021, 02:44 AM
Sag Harbor
, New York
Originally Posted by Mollysdad
. . . but look with envy at the 7000.
Have you considered selling the trailer, and getting an RV, in order to tow enough generator for your needs?
Happy trails,
05-15-2021, 07:12 AM
Tampa
Originally Posted by OTRA15
I had an RV with a 5500 Onan. 50 amp service with the push of a button!
I just know the guy who says, "I don't need the A/C or microwave" will have a wife with a hair dryer.
The right generator is the largest one that fits under the tonneau. (You pioneers with the hamster running on a wheel have my admiration, but "roughing it" to me is when the ice maker is down).
To be honest, although I have the 3K, I almost never use it. So far every place has power. Night at WalMart? Not yet, maybe this year. Boondocking? Not yet, maybe this year.
05-15-2021, 07:22 AM
Sag Harbor
, New York
What is an "ice maker" please?
05-15-2021, 07:58 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I am interested in what the OP asked the question seeing that he already has a 2000. Are you thinking about going to a smaller generator than that? If you have a EMS you could probably get a good idea of the loads for what you want to run. I run my microwave and my AC with a 2000 but have thought about how much lighter a 1000 might feel. I know I am not likely to actually downsize though. Will replace the 2000 with a 2200 if it gives up.
05-15-2021, 08:18 AM
1994 34' Excella
Warren
, Manitoba
The big question to me is "how often are you going to use the gen set?". I had a 3500W Honds with electric start the I carried for several years, when I was younger and could easily lift into the bed of the truck. I also carried a Honda 500W. The 3500W was sold last year with about 25 hours of use. I looked at the Honda 2200W, and was at the local Lawn and garden dealer and he had the Ducar brand 2000W generators in stock at half the price of the Honda. I bought 2, with the parallel kit for slightly more than 1 Honda. They compare in noise level to the Honda, weight wise they are about the same, and have almost the same warranty. The Harbour Freight generators are about the same. IF I was goung to use the generators 100 hours or more a year, then I would have bought the Honda's. The smaller generators are light enough that the wife can put them in the bed of the truck and set them up if needed. In 10 years they might not resell for as good a price as the Honda, but I really don't care! JMHO
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
05-15-2021, 08:23 AM
Sag Harbor
, New York
Originally Posted by Bill M.
. . . how much lighter a 1000 might feel.
Post #2:
. . . a Yamaha 1000 . . .
Ah . . .
