08-08-2018, 09:36 PM
#41
New Borockton
, Alabama
Originally Posted by pcskier
Randy, glad to hear it. I love mine. As a distributor, in concert with their efforts to enter the Airstream world, you might suggest that they try a redesign to try shortening the length of the male outlet assembly by a quarter inch or so. With the back cover installed, I had to modify the inner skin on both my 23d and my 23FB. The rear of the unit contacted the inner skin, not allowing the front to be flush with the exterior. It seems on other models, this isn't an issue. Could be based on where the outlet is located and if the space between the skins is a bit wider in certain places. All I know is that mine was a total no-go without getting my Roto-Zip out on both of my applications to cut on the inside. In the case of my 23 FB, I actually had to cut a hole in the interior skin to allow the assembly to fit, and reroute the interior Romex, from being between the skins, to inside the trailer, attaching to the outlet that stuck into the trailer a quarter inch or so. Fortunately it was down under the closet floor, so not anywhere noticeable. But I could see someone encountering this and just sending it back.
I mentioned this to them today. They were unaware and wondered like you said it was isolated to a certain model or 2 since so many have already installed smartplug without any issues. The company is interested our thoughts and really appreciated the feedback. He actually had read this thread so they are paying attention! They did point out that they do send them direct to Airstream and had not heard this from them. Thanks for the feedback pcskier!
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
08-12-2018, 10:33 AM
#42
Tampa
I'm surprised Airstream doesn't have a backing plate (square of plywood) to stiffen the area around the power inlet. Same with the SP mod. I'd think the plug hanging on the skin would distort the aluminum.
08-12-2018, 10:42 AM
#43
Slide Out Society #001
2007 30' Classic S/O
Somewhere
, South Carolina
Plywood or thick plastic backer sounds good.
I’ve only tackled one power inlet repair to check the connections. But the holes in the AL were mucked up from previous attempt with sections of AL as new threads behind it. Lots of old caulk behind it made it nasty.
To get s strong bite for the screws I used Spring Nuts https://m.lowes.com/pl/Spring-nuts-N...are/4294710807 and a bit of sealant as the choices were loose or secure and a little exterior sealant.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
08-12-2018, 11:30 AM
#44
2012 31' Classic
Austin
I did this upgrade 6 months ago. We have a 50-amp model so we needed the 50a receptacle. I also wanted the flexibility to use my 30 amp cord when needed. Alas, the receptacle's are different and there is no adapter between 30a and 50a. What I did was put a 50amp male on the end of my 30amp cord but made a mod for the 2nd leg that 50amp needs. Here is a blog entry about it:
https://www.casarodante.org/2018/02/...tplug-upgrade/
08-12-2018, 02:25 PM
#45
Dexter
, Missouri
Excellent product. Did the swap last year and no regrets. Took about an hour to do it. Only hard part was getting the old one out.
