Anyone have any suggestions on why and how to fix the lost power to our rear bedroom fantastic fan?
It has worked fine for years, and just quit two days ago.
I checked all the
12 volt breakers and none of them popped out. I also used a volt meter to check all the
12 volt breakers and they are all good.
I used the meter to check for power on the wires leading to the fan, nothing there.... no power to the wires.
I also made sure the fan's thermostat, on the wall next to the bed, was set to a low temp so the fan would work. Actually moved it up to high and down to low just to make sure that was not the problem. It had no impact on the power.
Someone mentioned to find the wire harness in the Airstream and see if a wire has come loose. Well, I looked under the dinette for a wire harness and there is nothing under there except a lot of wires, but no junction box or harness.
Any ideas? Thanks!
