Old 07-18-2021, 03:45 AM   #21
Silvr_Bullet's Avatar
2017 16' Sport
Great Town , US
Originally Posted by wulfraat View Post
Here is another basic diagram on how to wire a shunt to the factory system.
The employee at the dealership is incompetent when it comes to 12/120v electrical / ABYC standards and Iíll leave it at that
Also adding a second diagram that includes a proper battery cut off switch so you donít end up draining your batteries again.
If one had one lithium battery, how would the installation differ with no inverter. I am in the process of replacing my AGM 100 amp with a Lithium 100 amp, maybe a Battle Born. I would like to add a Victron 712 to replace the factory Sun Explorer. Add a Victron 30 amp Solar Controller ( and a Bluetooth Dongel ). I donít know if my current onboard battery charger supports Lithium. I have an 80 watt roof top solar panel and a 120 watt portable. This is in a 16í Sport. I am not having any luck finding someone in my area for an install, thinking of my residential electrician. Any advice would be appreciated as my experience with electrical is changing out a light switch.
Silvr_Bullet is offline   Reply With Quote
Old 07-18-2021, 04:38 AM   #22
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Not a lot I can add to the advice given by others, but I will agree that the bus bars used are wholly inadequate. Especially the negative bus bar.
One suggestion - if you are using anything which has set-screw terminal connection on it and you're using stranded wire it really helps to install a ferrule on the end of the wire before inserting it into the set screw terminal. Ensures that all the strands are playing their parts and not squished off to the side somewhere laying loose.
Richard
1974 GMC 4108a - Custom Coach Land Cruiser
richard5933 is offline   Reply With Quote
Old 07-18-2021, 07:06 AM   #23
Half a Rivet Short
Carlisle , Pennsylvania
Hi
You will need a converter / charger that is lithium compatible. The stock units normally are not.
You will need a solar controller. I would get the "Smart" Victron with the Bluetooth built in. It's cheaper than buying the "dumb" one and adding a dongle.
If you have a portable panel, it also would need a lithium compatible controller on it. With two small panels, having the controllers "fight" with each other does impact things.
I realize there is only so much space on top of a 16'. Still, I'd sure look into fitting another panel on the roof.
Diagram wise it's all the same. You just don't have the second battery.
Like anything on an RV, there *is* a value in learning how to do this or that. You never know when a problem will pop up 200 miles from nowhere / with no cell service
Old 07-18-2021, 09:59 AM   #24
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Originally Posted by Silvr_Bullet;
If one had one lithium battery, how would the installation differ with no inverter. I am in the process of replacing my AGM 100 amp with a Lithium 100 amp, maybe a Battle Born. I would like to add a Victron 712 to replace the factory Sun Explorer. Add a Victron 30 amp Solar Controller ( and a Bluetooth Dongel ). I don’t know if my current onboard battery charger supports Lithium. I have an 80 watt roof top solar panel and a 120 watt portable. This is in a 16’ Sport. I am not having any luck finding someone in my area for an install, thinking of my residential electrician. Any advice would be appreciated as my experience with electrical is changing out a light switch.
See attached. no inverter is easy, just eliminate that cable to / from the battery. Your solar charger will connect to the positive and negative bus bars in black / red in the diagram.
wulfraat is offline   Reply With Quote
Old 07-18-2021, 10:35 AM   #25
AirstreamJim's Avatar
2009 34' Classic
Lake Worth Beach , Florida
I agree; I was a bit surprised to see them so tightly packed, as nothing new has been added to them. I believe the bus bars are original to the trailer. Iíll see about replacing them as well.
WBCCI 1433
🌴 Palm Beach County, FL 🌴
Silver Meteor - 2009 Airstream Classic Limited 34
2016 RAM 2500 Laramie Crew Cab 4x4, Cummins TurboDiesel
AirstreamJim is offline   Reply With Quote
Old 07-18-2021, 01:40 PM   #26
2017 16' Sport
Great Town , US
Lithium & Solar Issue
wulfraat and Uncle_Bob thanks for your expertise. Will I be able to reuse circuit breakers from the on board charger to the new one that will support the Lithium battery . Thanks
Old 07-18-2021, 02:30 PM   #27
2017 16' Sport
Great Town , US
Just watched a YouTube video and now I know that the fuse box and the converter are separate and distinct , I know the answer to my question I quoted here. You now understand my limited knowledge. So no need to answer. But any advice or comments are welcome. Thanks
Old 07-18-2021, 02:45 PM   #28
wulfraat's Avatar
Airforums is a great place to learn. I knew zero (0) about any of this stuff until we got a trailer. Comes over time and there is a lot of great folks on the forum who will share their knowledge and expertise.
All good! Airstreams are awesome!
Old 07-20-2021, 07:29 PM   #29
2009 34' Classic
I've supplied the dealership with the attached schematic for them to follow when they fix their poor workmanship. Please let me know if there's anything seriously wrong with it before it's too late.
Thanks again for everyone's help.
WBCCI 1433
Old 07-20-2021, 08:07 PM   #30
wulfraat's Avatar
Very close. Your inverter hot (red) should be wired to the to the right of the disconnect switch but before the ďDC fuse blockĒ. Otherwise your converter cannot power 12v loads in the trailer when the batteries are disconnected from the system. The wire from the converter actually bolts to the disconnect solenoid switch itself IIRC.
Negative from the inverter should connect directly to the top of the shunt itself, not the bus bar. It draws a lot of current and the bus bar is not rated for that load. Same for red / positive to the inverter - that should go straight to the positive battery terminal bypassing the positive bus bar.
There should also be a tiny red line from the shunt to the positive battery terminal (it gets a tiny amount of constant DC power to stay alive 24/7)
Finally, technically, from your solar controller, you should show 2 wires headed off to the solar panels. Not needed really but for the avoidance of doubt....
Nice work. Next time you need to troubleshoot something you will be a pro because you know how this stuff works!
Old 07-21-2021, 10:05 AM   #31
Happily Chuggin' Along
Dozer1960's Avatar
2020 30' Flying Cloud
Buchanan , Tennessee
@Wulfrat - I have been following this thread and learning like everyone else.I printed the diagram and am making changes you suggested but there appears to be a contradiction. Please help me understand where I might be missing something.
First - you have him move the RED Inverter wire to the right side of the shut off switch, that makes perfect sense to me.
Then you say, same for the Red/positive from the Inverter, that should go directly to the battery and bypass the positive buss bar.
Is there a line missing in the drawing or can you help me understand what you meant here?
Thank you and this is great work, as you said, we all learn along the way.
Brian
2020 Flying Cloud RBQ
2020 F-250, 7.3L Platinum
Blue Ox Sway Pro
Airstream Club International - Carolinas 10124
Dozer1960 is offline   Reply With Quote
Old 07-21-2021, 10:44 AM   #32
rich.dev's Avatar
2016 26' Flying Cloud
Guelph , Ontario
Jim, I've enclosed a basic layout of the batteries, shunt, disconnect switch and fuses in sequence I believe they should be. Looks like your negative from the battery to the shunt is ok, however, in your configuration I believe the inverter negative should connect directly to the output side of the shunt.
Also, in my enclosed diagram you will notice an ANL fuse coming from the poss side of the battery, then a disconnect switch and the inverter connected directly to the disconnect switch.
Name:	RDV Lithium upgrade.png
rich.dev is offline   Reply With Quote
Old 07-21-2021, 10:54 AM   #33
wulfraat's Avatar
Did this real quick per the original diagram in this thread...
Old 07-21-2021, 11:46 AM   #34
1994 25' Excella
I would add one thing - a circuit breaker between the solar controller and the positive connection to the system. Victron recommends a circuit breaker in that location, and by using a switchable breaker it's possible to use it to disconnect the solar system from the trailer's 12v system. This is quite helpful when you're working on something and need to be sure that there is no power coming into the trailer.
Richard
Old 07-21-2021, 07:49 PM   #35
2009 34' Classic
For some reason this diagram completely confuses me, and Iím not sure whyÖIím usually very adept at following electrical diagrams. :-(
WBCCI 1433
Old 07-21-2021, 07:56 PM   #36
2009 34' Classic
Now this I understand.
Thank you so much! Iíll give this to the dealership when we bring it back.
I wrote them a long email last night outlining the issues and including my original schematic and some photos. I got a phone call from the service manager at 8:40 this morning apologizing for the poor work. Theyíll be waiting for me on 7/31 first thing and theyíll get it corrected the same day. And Iíll check the whole thing over before I take it home.
Iím satisfied with their response so far.
WBCCI 1433
Old 07-21-2021, 08:55 PM   #37
wulfraat's Avatar
Sweet glad they will get this fixed up right quick!
Old 07-22-2021, 08:51 AM   #38
rich.dev's Avatar
Guelph , Ontario
For some reason this diagram completely confuses me, and I’m not sure why…I’m usually very adept at following electrical diagrams. :-(
If it's the SafetHub 150, sorry I should've clarified, the SafetyHub 150 replaces your neg and pos buss bars. You don't need it, just a more compact way of combining the neg and pos buss bars. Anyway, the diagram from Wulfraat is good.
I do agree with richard5933 to add a circuit breaker between the solar panels and solar charge controller on the positive side.
Old 07-22-2021, 11:24 AM   #39
2019 Interstate Lounge Ext
Noblesville , Indiana
In my designs, I use a Victron Battery Protect devices. It can be set to disconnect your DC loads BEFORE your Battleborns go into a disconnect state via their BMS. It's only about $100. It also allows you to disconnect all DC loads via bluetooth if you desire.
vanderwielen is offline   Reply With Quote
Old 07-22-2021, 02:04 PM   #40
Half a Rivet Short
Hi
If you are talking about the BP-xxx Victron devices, be aware that they have some *really* odd habits. It is unclear to many just what the target audience is. I had a couple of them (BP-220) in my system and eventually pulled them all out.
New Lithium & Solar Upgrade ChrisCow Sprinter and B-van Forum 29 05-28-2021 09:43 AM
Guidance on Lithium Ion & Solar ghaag Electrical - Systems, Generators, Batteries & Solar 39 10-31-2018 07:37 AM
600w of Solar and 400 amp lithium charlesk Generators & Solar Power 11 10-07-2016 01:35 PM
Lithium Batteries for Solar ghaynes755 Generators & Solar Power 26 01-13-2015 09:02 AM
Electrical, Solar, Lithium Batteries on 28' International wbrown Electrical - Systems, Generators, Batteries & Solar 25 09-13-2014 06:44 PM
