RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 03-27-2019, 03:44 PM   #1
2016 23' Flying Cloud
Fanwood , New Jersey
Lights hack -- Polarity?
I've never done it, but I think it's interesting.
https://letscampsmore.com/running-lights-hack/
Here is my question. When you do this trick, do you think the polarity is unchanged from the normal ways these lights are powered?
Why do I want to know? Well, I'm wondering to check the polarity of cables (say for example, cables feeding license plate light) with this method without hitching to a TV.
I know I can/should experiment, but I'm lazy.
Atsushi is offline   Reply With Quote
Old 03-27-2019, 04:10 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
I built a little box with a 7pin female plug that is jumped out with a wire between the battery hot and running lights. It also has a switch that allows me to turn them on and off. It works great.
Old 03-27-2019, 05:19 PM   #3
2007 22' International CCD
Personally, I’d deeply dislike anybody out camping in the boondocks and deliberately turning on their running lights at night while parked in a site within my view.
I want to see the stars and scenery, not excess running lights, strings of lights, LED strings, whatever.
For test purposes, an adapter box is a darn good idea. A 7-way receptacle in an aluminum box would be rather handy. One more idea for my rapidly growing list of projects, sigh.
Old 03-27-2019, 05:38 PM   #4
Johnco's Avatar
2006 19' Safari
Anaheim , California
I built one with a two way switch. One circuit is constant on, the other circuit routes through a flasher. It's a back up if I have to leave the trailer roadside at night without the tow vehicle.
Think like a Proton-Stay Positive!
Johnco is offline   Reply With Quote
Old 03-27-2019, 05:42 PM   #5
2017 27' International
Lake Havasu City , Arizona
"When you do this trick, do you think the polarity is unchanged from the normal ways these lights are powered?"
I don't see jumpering those two pins could reverse polarity. And if you have LED running lights on your 2016 FC, they would not operate if polarity were reversed...so if you do it and they light up, you have your answer.
Paprika is offline   Reply With Quote
Old 03-27-2019, 05:53 PM   #6
Long Island , New York
I guess flashing lights would be OK?
OTRA15 is online now   Reply With Quote
Old 03-27-2019, 06:25 PM   #7
Johnco's Avatar
2006 19' Safari
More than OK if you're stuck on the side of the road. You have to give the impaired drivers something to aim for...
Old 03-27-2019, 06:54 PM   #8
Flashing lights would get a very loud visit from DW to that person’s campsite. I would be deeply concerned for the miscreant’s personal safety at that point...
And yeah, it’s well known that impaired drivers use flashing lights to define their aim point center—and they usually hit it squarely.
Old 03-27-2019, 07:36 PM   #9
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
That’s the same thing I did. Flasher is nice if you had to drop the trailer for some reason.
Old 03-27-2019, 08:24 PM   #10
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Polarity is unchanged. All you are doing is providing a 12v+ Connection to the positive wire of the running lights. Same thing your TV does through the 7 pin cable when your running lights are on. The only difference is you are using the trailers 12 volt system to power the running lights through a jumper.
Old 03-28-2019, 12:18 PM   #11
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
There is no need to build a flasher. There are many variations that plug directly into the 7-way available on the net. Search for "two-pin 12 volt signal flasher". I stash mine in the glove box for that unforeseen roadside emergency.
Here is an example that works for newer trailers with LED markers:
https://www.ebay.com/itm/2-Pin-12V-E...e/153282229941
The older filament style bulbs use solutions like this one:
https://www.ebay.com/itm/2-PIN-Prong...D/223314822795
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Hi, I need mini Polarity lights for 1973 land yacht. RNgirl Airstream Classifieds 0 01-14-2018 10:49 PM
Hi, I need mini 2 or 3 Polarity lights for 1973 land yacht. RNgirl Airstream Classifieds 0 01-14-2018 10:47 PM
8-Track or Hack? Rivetedude Audio, Video & TV 12 05-19-2005 06:02 PM
