I'm doing finishing touches to my Safari (the one with the new dinette), which includes better lighting. I'm putting "pucks" in the ceiling center panel. A few years ago I posted that cutting this panel is almost the only way you can work on by yourself. It's not pretty, but it's not ugly, either.
First step is to gain access to the ceiling area. So you take down the vent bezels and the air conditioner lower half, then remove the pop rivets at the ends of each section of the ceiling panel. Bow each section downwards and then it's easy to slip out of the edge channels.
The pucks I happen to have on hand have a pair of tabs on the inner body, so I removed the outer shell, cut an appropriate hole(s) in the ceiling panel(s) and used the tabs to secure the pucks in the panels. It was a simple twist and they locked into the panel.
With the panels installed and the bezels back up, the ceiling looks fine and the illumination from just two LEDs is very bright. On full brightness they take about 350 ma each and on dim (see next post) about 100 ma each. If you look real close you can see the tiny switch (with a red handle) in the center of the first photo below. You can see the patch where I removed the center vent. Three vents in a 23' Airstream are a little excessive with the Fantastic Fans that are now available, plus you get some room for solar panels if you want them permanently on the roof.
Zep
