RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 02-05-2018, 06:04 PM   #1
2018 28' Flying Cloud
Gainesville , Florida
Leaving AS connected to land power
Newbie question: Is there any reason not to leave our 2018 ASFC 28 50AMP connected to land power (50 AMP) while it is awaiting our next trip. Parked in our driveway in Florida?
Bruceandbarb is offline   Reply With Quote
Old 02-05-2018, 07:40 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30 Globetrotter
2014 23' International
Dadeville , Alabama
Nope
Nope, mine stays plugged in and ready to go at a moments notice.
Old 02-05-2018, 07:41 PM   #3
Byron Center , Michigan
It shouldn't hurt it, especially since you have a newer trailer with a multi-stage converter that should be able to float the batteries correctly. If you have wet cell batteries, I'd still be sure check the water levels regularly. AGM's (that come with the solar set-up) will be fine.
YippieKiYa is offline   Reply With Quote
Old 02-05-2018, 08:54 PM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi bruceandbarb: Welcome to Air Forums. Nice to meet folks with a brand spanking new Airstream. May you have many enjoyable adventures with it.
In the old days of single voltage converters, we often left the trailer unplugged and took the battery out for the winter. Now they build multi stage converters that just trickle charge the batteries and won't overcharge them and thus dry them out.
I understand the new Airstreams have multi stage converters. They won't cook the battery dry. So you should be okay.
David
WBCCI #8607
VAC Region 11
See my 1966 Trade Wind Renovation Documentation:
Knowledge Base Airstream Trailers
See my 1975 Overlander Improvement Journal:
See our 1976 Sovereign Renovation Project:
Old 02-05-2018, 10:11 PM   #5
Thanks for the replies! I was getting unreliable information from a dealer salesman.
Also we feel very fortunate to have a new AS, a bit spoiled in fact. We've owned a different brand TT and a class B, the AS is our dream.
Old 02-06-2018, 12:05 AM   #6
2016 30' International
redondo beach , California
We have our 50 Amp trailer plugged in 24/7. Since we just keep the batteries charged and the fridge cool there is no need for that fat 50Amp power cord. We use a regular extension chord with an adaptor.
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Old 02-06-2018, 06:25 AM   #7
Make sre cord is rated at enough amps or it can overheat the adapter. Maybe use a 30 amp cord..
Old 02-06-2018, 10:14 AM   #8
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Sometimes I leave mine plugged in for months at a time.
Difference in light bill is barely noticeable- like $10-$20 a month more.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 02-06-2018, 10:20 AM   #9
2017 30' Flying Cloud
Spotsylvania , Virginia
Very interested in these answers as I have a 2017 with the solar package which is supposed to keep my batteries charged.
I had a 2015 23 FB before purchasing the 30' FC and the switch had to be in the "use" position to charge the old wet cell batteries when plugged in to land / shore power.
Does the 2017 30' FC need to have the battery switch in "use" to charge the batteries while plugged in?
I assume (and I hate to use that word) with the solar system on the roof it automatically charges the batteries without the battery switch being flipped to "use."
KWN306 is offline   Reply With Quote
Old 02-06-2018, 10:50 AM   #10
2014 27' FB International
boerne , Texas
what year did AS move to newer converter
ortho is offline   Reply With Quote
Old 02-06-2018, 10:55 AM   #11
2018?
Old 02-06-2018, 11:40 AM   #12
1976 31' Excella 500
Chappell Hill , Texas
Always plugged in. No issues.
tbashin is offline   Reply With Quote
Old 02-06-2018, 11:49 AM   #13
2012 25' Flying Cloud
Naples , Florida
what cord then? the orange ones for outside?
ekm217 is offline   Reply With Quote
Old 02-06-2018, 12:03 PM   #14
2007 22' International CCD
Don't assume anything--verify that the solar charges the batteries when in 'store'. I figured out that my self-installed solar system was wired to the wrong side of the use/store relay after my batteries went flat on me with the AS in full sun. I had guessed which lug of the relay to run my charge line to, and missed.
Old 02-06-2018, 12:27 PM   #15
Boxite's Avatar
2008 22' Sport
Different models .... different years, I believe. My 2008 has a factory-installed WFCO multi-stage converter and it's been plugged into shore power continuously with no problems whatsoever.
Old 02-06-2018, 01:45 PM   #16
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
We keep ours plugged in. I even run the AC at 80 degrees in the summer months to prevent heat and humidity damage inside (e.g.: mold, wood warping, etc.)
GammaDog is offline   Reply With Quote
Old 02-07-2018, 05:17 AM   #17
FCStreamer's Avatar
2014 30' Flying Cloud
This is what I do. To prevent the batteries from overcooking, I keep them in the Store position and I use an external battery charger to keep them topped off. So far so good!
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
No 110 power connected to shore bonginator Electrical - Systems, Generators, Batteries & Solar 3 06-25-2010 08:53 PM
Battery at 45% even though connected to shore power SilverGate Batteries, Univolts, Converters & Inverters 27 04-17-2009 05:35 PM
Leaving batteries connected over the winter StAlphonzo Electrical - Systems, Generators, Batteries & Solar 7 10-02-2008 03:44 PM
Leaving trailer connected to 110 ac? jglabrown Electrical - Systems, Generators, Batteries & Solar 1 09-28-2006 10:36 AM
TV connected & on shore power? Kistler Audio, Video & TV 4 04-03-2004 06:12 AM
