05-18-2024, 06:38 AM
Naysayer
1968 24' Tradewind
Russellville
, earth
Is this common? Surge protector flipping on connection
Background: during the rebuild of my Tradewind a couple years ago, I had the electrical system rebuilt including a surge protector (I should say I THINK that is what the device is) wired into the system. The entire system was designed by AM Solar. Until this summer, I rarely have had occasion to plug into shore power so I am not really all that familiar with that side of the house.
On two occasions in the last three weeks at two different campgrounds, I have had to reset the breaker on the surge protector that appears to have flipped immediately after plugging in to the pedestal. Is this normal and to be expected or should I be looking at the surge protector more closely?
05-18-2024, 07:45 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
Many surge protectors have a display that tells you why it tripped.
That does not sound normal or expected to me. But...I have had a couple of campground with low power over the years. Not often though.
My surge projector is a electrical management device with a red display that tells why it tripped and gives the volts and amps when it is working. I cannot imagine that AM Solar would install a system without some sort of read out. You just need to find it.
05-18-2024, 09:02 AM
1994 25' Excella
Waukesha
, Wisconsin
What's the brand/model of the surge protector?
I'm suspecting that what you have is not a surge protector but rather some version of an EMS - designed to protect against more than just a surge like reversed polarity, high voltage, etc.
There are lots of things which could be triggering the unit to shut off power. For a system not used on shore power often I suspect that it's seeing an open ground, low voltage due to a loose connection, or something in the shore power cord/connection which it doesn't like.
Not at all uncommon for things to work loose in the 120v system over time. Have you checked all connections to make sure they are tight and clean? Have you tried another shore power cord?
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
05-18-2024, 09:19 AM
2022 25' Flying Cloud
NCR
, Ontario
get the remote display for your surge box
it will tell you what occurred . often its mis-wired feed, missing ground, corroded connections etc.
2023 25' FB FC, hatch, Queen,30A,1AC,Awning pkg, Convection uwave.Multiplus 12/3000-50,700A Lion,MPPT 100/30,Orion-TR 30,Cerbo GX,GX touch 50,Lynx distributor,dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors,2 Mopeka LP sensors
NCR,Ontario,VE3HIU since 1978
WBCCI# 21212
05-18-2024, 12:12 PM
2021 27' Flying Cloud
Wake Forest
, North Carolina
AM Solar is excellent at supporting their products and installs. Have you given them a call? They can usually pull up your configuration and help you over the phone. I purchased all my electrical upgrades through them and they have been fantastic about providing me with support to help me get it all dialed in correctly.
2021 27' Flying Cloud FBQ, Rear Hatch,
480w Solar, 400ah Lion Energy Lithium,
3000w Multiplus II, Dual Orion 30a DC-DC Chargers (60a total), 3" Lift kit, Maxxair Fan
2020 RAM 2500 6.7L Cummins Diesel
05-18-2024, 12:19 PM
2021 30' Flying Cloud
Airstream - Other
Airstream - Other
Lady Lake
Give Them a Call
Always go back to what was last touched and who touched it . Loose wires? correctly routed wires? I would give the company a call they are good people.
05-29-2024, 02:06 PM
2019 30' International
Spring
Make sure the breaker at the pedestal is flipped to off before connecting your power cable. I flipped two breakers plugging in while the power was on before I knew better. Might not be your issue.
