RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 07-19-2019, 10:10 PM   #1
2017 27' Flying Cloud
Sioux falls , South Dakota
Inverter help 2018 FC 27FBQ
I have a recurring problem. Intermittently, the inverter AC bypass shuts down. No lights on the display. No power at the inverter outlets. Microwave also shuts down. The current work around is to plug the inverter into an alternate outlet. As a precaution I unplugged the microwave and am using an alternate outlet. Power to the inverter outlet is intermittent and when non-functional, the convection microwave outlet is also non-functional. Why would the factory wire an appliance that requires 1500 running watts to the inverter that supplies 1000 watts. The problem is not directly linked to the operation of the microwave. Did the factory run a hot from the inverter to the dedicated microwave circuit? Airstream located the inverter in a location that it is impossible to read the display. I am thinking the inverter outlet maybe bad or have a bad connection.
Sitesee is offline   Reply With Quote
Old 07-22-2019, 08:10 PM   #2
waninae39's Avatar
2017 22' Sport
NCR , Ontario
we replaced our stock unit with a Victron 3k inverter/ converter. it work in conjunction with the solar panel and BB lion battery.
we also get remote and phone access.
now all outlets can be used , no more 1k limit
waninae39 is offline   Reply With Quote
Rear hatch 27FBQ Renascence 2016 - Current Flying Cloud 1 07-17-2019 04:56 PM
Question? Replacing factory converter & inverter with 2k watt inverter charger cptdzl Batteries, Univolts, Converters & Inverters 1 06-23-2019 08:55 AM
Please help: 2018 Globetrotter => 2018 F-150 Lariat SuperCrew Confirmation ddrg Tow Vehicles 167 03-11-2018 07:16 AM
prep for my solar future: Inverter charger/inverter-converter combo wonderlust87 Electrical - Systems, Generators, Batteries & Solar 1 09-13-2017 11:50 AM
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 02:48 PM
