Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 11-22-2021, 10:27 AM   #1
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
Inverted outlets
In the process of upgrading to lithium with 30amp inverter. I would like the ability to run the convection/microwave, coffee maker from kitchen outlet, & hair dryer in the bathroom. I do realize, I can probably only run one at a time on each 15amp circuit. The irritation here is, the kitchen outlet is not inverted, neither is the microwave, and guessing nor is the bathroom. Iím going to try to figure out the easiest way to invert the microwave and kitchen outlet. Has anyone done this?.
The tv outlets have one outlet available, the other is non-usaeable. Is there a reason other than limiting a potential overload if someone plugs a high draw appliance while the stereo and tvís are on?
- Stewart
s1000pre is offline   Reply With Quote
Old 11-22-2021, 08:07 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Inverted outlets
The reason is that they are dedicated inverter outlets and itís to limit potential 120v AC draw on your current 1000w inverter.
The devices you are referencing are on 2 or more AC circuits. Putting everything on one circuit and being mindful not to run one more than one thing at a time is not a best practice / might be against code.
There is equipment (pass through inverter chargers) that solve for this. A traditional inverter is design to power a single AC circuit.
wulfraat is offline   Reply With Quote
Old 11-23-2021, 02:56 AM   #3
2020 30' Flying Cloud
Fayetteville , Georgia
When I installed my Victron Multiplus inverter, I completely removed the 1000 watt inverter. The factory inverter was on AC circuit 7. I connected the wiring going into the inverter with the wiring that was going out of the inverter. That completed the circuit to the TVs etc. Look in your owners manual for the wiring diagram.
As per AM Solar wiring diagrams, my Multiplus is connected between the shore power input and the main AC panel (SPS installed too). So the Multiplus powers all AC outlets when donít have shore power. You have to remember that you canít run everything simultaneously, just like at a campground with 30 amp service.
It is very convenient to be able to use the microwave or coffee maker when stopped for fuel. Iíll pull into the diesel line and my wife gets started on lunch.
My 2 cent.
T Mac is offline   Reply With Quote
Old 11-23-2021, 07:17 AM   #4
s1000pre's Avatar
I’m hearing everyone’s comments on this subject, and appreciate the feedback. I came up with another option which will give me some redundancy as well (option B).
Option A. Install Victron 3000, ditch my converter, move everything around and spend 80-100 hrs figuring it all out and re-wiring my 30bunk.
Option B.
1.Swap out my converter with a progressive dynamics PD9160 (plug & play).
2. Add an additional Inverter PD1618 (1800 watt) to carry the 15A microwave circuit, two galley and bathroom outlets.
I have already experienced a bad inverter on the road which AS quickly replaced. This setup would give me the redundancy and ability to swap inverters in a pinch.
I would only need to use the second inverter when I want to use the microwave, or outlets.
I realize the microwave, hair dryer, toaster, or coffee maker can only be used one at a time, we are used to doing that anyway. The bonus is I can complete this setup in an afternoon.
Any thoughts or opinions?
- Stewart
Old 11-23-2021, 08:17 AM   #5
Flagstaff , Arizona
Originally Posted by s1000pre View Post
Iím hearing everyoneís comments on this subject, and appreciate the feedback. I came up with another option which will give me some redundancy as well (option B).
Option B.
Suggest you install the MultiPlus-II and be done with it. You will have an AC electrical system just like your house with the bonus of using shore power connections of less than 50 amps letting the lithium batteries make up for temporary surges of demand that exceed a 20 amp or 30 amp shore connection.
goldenchase is offline   Reply With Quote
Old 11-23-2021, 08:57 AM   #6
2018 30' Flying Cloud
Anchorage , Alaska
Option B may not be as simple as you think. An 1800 W inverter will pull around 170 A DC and need at least 1/0 wires to feed it. It should be located up front by the batteries. You then still need to run the AC to the distribution center toward the back of the camper. If you put all those things on one circuit, yes you will only be able to use one at a time, but that is permanently true, even when youíre on shore power. Not sure youíd want that.
Iíve been down this road, trying to come up with an easy way to power just a few things. I ended up just installing a Multiplus and rewiring the camper.
AKNate is offline   Reply With Quote
Old 11-26-2021, 04:56 PM   #7
2016 23' International
Los Altos , California
Anybody have wiring diagrams they can share for victron multi plus inverter charger retrofit for airstream
Also adding 4 Battleborn batteries and relocating them under front bed near new victron
jsmall01 is offline   Reply With Quote
Old 11-26-2021, 05:08 PM   #8
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
Hereís how I added 500ah of lithium and a Victron Multiplus 3000 under the curb twin if that helps.
ID:	408475   Click image for larger version
daleyocum is offline   Reply With Quote
Old 11-26-2021, 05:15 PM   #9
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
There are as many ways to wire one of these as there are people doing it.
The Victron has two outputs - one that is always hot whether you're running off the inverter or on shore power, and the other only hot when on shore power. This is designed so that when you lose shore power your larger items like the a/c units, electric water heater, space heaters, etc. won't immediately overload the system and cause it to error out.
Doing this type of install requires all the circuits which should only run off shore power to be separated from those which can run off either shore power or the inverter.
On my coach I installed one of the new Victron Multiplus inverter/chargers and did it where everything on the coach is fed from the Victron on the always-hot output. I didn't want to go through the trouble of installing a sub panel and rewiring things. What this means is that before I disconnect shore power I have to carefully shut off anything which will have too large a load for the inverter.
After a season of traveling with it this way, I'm thinking that I should have installed the sub panel and done it with two separate outputs. It's not that difficult to shut things off when disconnecting from shore power, and it only took a few times of forgetting something and having the system shut down to make a point of remembering.
The problem comes when shore power blips out, even momentarily, while you have something with a large load running. As Murphy would have it, the power at the campground is going to have the momentary outage while your a/c is running, your space heaters are on, etc. Then the Victron will require a reboot to get going again, not something ideal especially in the middle of the night.
If the two separate outputs are used the Victron will automatically and instantly shed the loads which are on the shore-power-only output whenever the shore power is lost. Makes for a much smoother operation all around.
All that said, if you have a large enough battery bank and enough inverter capacity to handle your largest loads for a short while you may not have the same problem.
Richard
11018
1974 GMC 4108a - Custom Coach Land Cruiser
richard5933 is offline   Reply With Quote
Yellow tape with Inverted Male Flare? PSU1981 LP Gas, Piping, Tanks & Regulators 6 06-14-2018 09:29 PM
Inverted circuit out jar1950 Batteries, Univolts, Converters & Inverters 4 01-13-2018 11:19 AM
Inverted strength? dquirk29 Batteries, Univolts, Converters & Inverters 10 03-30-2016 11:31 AM
1/4" inverted male flare adapter? Smoky LP Gas, Piping, Tanks & Regulators 5 10-27-2009 09:44 PM
Use household 110 Outlets? mcostanzo Electrical - Systems, Generators, Batteries & Solar 5 06-26-2003 11:30 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
