Old 11-07-2023, 01:46 PM   #1
2008 31' Classic
Rochester , NY
Interior Outlets
We have a 2008 Classic and need to replace a couple of the 15AMP outlets. I have tried finding the outlets listed in the parts book, but the only one I find available is a GFI. Am I missing something in the parts book?
Or can I buy an outlet + box at Lowes/Home Depot and use that?
Thanks is advance for replies.
Wyokirk is offline   Reply With Quote
Old 11-07-2023, 02:00 PM   #2
ZOZ
ZOZ's Avatar
2018 23' Flying Cloud
Peru , Illinois
Outlet Mall
Use the 2015 Parts Book or Home Depot
2015 CLASSIC TRAILER
II-24
ELECTRICAL, 12 VOLT
Interior Receptacle/Switches/Covers
510868-03 Switch panel, 4-gang, white
511327 Switch body w/rocker, 1 gang, white
511328 Cover switch, one gang white
511566-01 Cover, switch, 2 gang
511567-01 Switch body w/switches, 2-gang, black
511771 Switch assembly, two-gang, white
500967-01 Cover, blank, Ivory
512709 Switch, Slide Dimmer Black #AH-SL
512312 Switch Assembly, reversing, Black
510888-05 Receptacle w/cover, GFI, White
510888-07 Receptacle cover, white
512480 Water heater switch assembly, white
510315 Switch and Receptacle box
511814-01 Receptacle, Duplex, Gray
511815-01 Receptacle, Duplex, Black
511287 Receptacle, Single, 15 Amp
512826 Switch, Rocker, Split, Stainless Steel
512825-03 Switch frame, 3 gang, Stainless Steel
512827 Switch, Rocker, Change-over, Stainless Steel
512825-01 Switch frame, 1 gang, Stainless Steel
512825-02 Switch frame, 2 gang, Stainless Steel
511912 Plate, Receptacle, Stainless Steel
zoz
Cindy & Randy
2018 AS Flying Cloud 23FB
2018 GMC Sierra Denali 4x4 6.2L
ZOZ is offline   Reply With Quote
Old 11-07-2023, 02:26 PM   #3
North AL , Alabama
You'll likely need a low profile RV style outlet like this one:
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
A standard residential box won't fit in the space between the skins.
They're a hassle to install without the proper tool as the wires have to be forced into grooves that cut the insulation and hold them in place. Can be done with some wood and a big C clamp if you're careful.
Tyler2you is offline   Reply With Quote
Replacing interior 120v Outlets Soyboy Electrical - Systems, Generators, Batteries & Solar 5 11-02-2017 05:35 PM
A Plan to Wire Inverter Power to all Interior Outlets - Need Review kscherzi Batteries, Univolts, Converters & Inverters 6 09-02-2017 01:32 PM
Interior outlets dead craiglkirk Electrical - Systems, Generators, Batteries & Solar 3 02-21-2016 04:28 PM
Interior Outlets - inverter powered kaylorsan Sprinter and B-van Forum 14 08-27-2013 04:09 AM
12 V outlets - interior replacements pageclot Lights - Interior & Exterior 2 04-22-2009 08:10 AM
