Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 04-19-2020, 10:11 PM   #1
wareaglewalt's Avatar
2017 25' Flying Cloud
Bushnell , Florida
Installing solar controller upgrade
I'm upgrading the Atkinson solar controller and display from the stock controller that came with our 2017. Install instructions say to cover the panels on the roof. Question is can I just do the install at night since getting to the panels on the roof is difficult? It's essentially just swapping out the controller unit and wiring back to what is already there.
wareaglewalt is offline   Reply With Quote
Old 04-19-2020, 10:30 PM   #2
2019 22' Sport
Carlsbad , California
I don’t see why not, lack of light is the real requirement. Maybe make sure it isn’t a full moon and you are parked under a streetlight?
Prettygood is offline   Reply With Quote
Old 04-20-2020, 08:47 AM   #3
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
Sure doing it at night works. On some (all?) Atkinson controllers the green negative solar prewire is connected directly to the negative busbar instead of the controller. On a replacement controller (Victron) you need to connect the green solar prewire directly to the negative terminal on the solar controller. I would also suggest upgrading the wires going to the busbars with 6 gauge wire and adding a 40A breaker on that wire. And while your at it you could install a shut off switch on the solar prewire before the solar controller.
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Upgrade factory solar controller DKGA Generators & Solar Power 37 07-23-2020 07:56 PM
Installing a 2nd fridge in 22' Sport (or installing larger fridge altogether)? skicrazy801 2005 and newer - Bambi all models 12 09-22-2019 01:43 PM
Installing a DirecLink Brake Controller in Lexus GX-460 OrangeKid Brakes & Brake Controllers 7 04-03-2013 11:54 PM
2008 Suburban - Installing Brake Controller adonh Tow Vehicles 11 03-22-2012 12:00 AM
Installing Brake Controller The Flintstones Brakes & Brake Controllers 4 10-31-2006 09:07 PM
