Old 10-15-2023, 01:31 PM   #1
hshovic's Avatar
2007 25' Safari FB SE
Bozeman , Montana
Images: 20
If you Stream long enough: lucky wiring solution
Greetings,
Our 2007 Safari FB has 150,000 miles. And like if you live long enough everything happens to you, well it happened to me.
My front interior lights and stereo went dark. After a thorough check, I wired power to them from the subwoofer circuit. And snaked wires to the stereo/lights. Worked.
A month ago the bathroom lights quit. After a thorough check, I wired power to them from the switch. And snaked wires way in back to the lights. Worked.
Two weeks ago the bath fan quit. One week ago the two fantastic fans quit. AAACCKKK!
So after taking it all apart I decided to snake wires to the bath fan cause
they appeared to be on the same circuit as the fantastic fans. I tried it with an external wire, and it worked. SOOOO,
As I snaked the wire behind the bathroom sink, the fantastic fans went on, then off.
What??
There is a multi-wire connector back there. But it looked plugged in. I touched it and LO, it fell apart. After effort, I plugged it back in and locked it. The bath fan and the fantastic fans worked! I took off my bath light wiring, replugged the original, and the bath lights worked! I believe it probably would solve the front light problem too. I took all my wiring out.
It is possible after all this time and miles, either the plug was never totally locked, or it just fell out from vibration. Wisdom does not necessarily come with age, but luck does.
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
hshovic is offline   Reply With Quote
Sewer hose how long is long enough? WhereStream Waste Systems, Tanks & Totes 41 10-17-2017 05:58 PM
The Long long long trip Foiled Again Full-Timing, Winter Living & Workamping 39 03-24-2016 10:27 AM
How Long is Long Enough? Oxen Tow Vehicles 20 10-25-2015 11:34 PM
Lucky 28 :: 1962 Air Stream Safari indy Airstream Registry Discussions 0 08-19-2011 08:32 AM
