RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-14-2017, 09:22 PM   #1
1972 23' Safari
Flintridge , California
How to make an original Ammeter work?
Hey dudes,
I have a '72 Safari and it is mostly intact. Sometime in its past, the Univolt was replaced and the original fuse board disappeared. As I understand it, there was a shunt of some sort connected to it to make the central control ammeter run which disappeared with the Univolt. Does anyone know of a way to return functionality to the ammeter without the original fuse board or have knowledge of how to make a shunt to replace it?
-miker
Junk Man is offline   Reply With Quote
Old 10-15-2017, 03:37 AM   #2
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
In my 77 MH this is a page from the manual showing the fuse panel, shunt & stuff.
If nobody has the exact specs, and you are trying to preserve the original meter, you will need to see how many millivolts it takes to deflect the meter to a known amperage. From there you can find out what shunt to buy that matches that ratio.
Or there are a bunch of aftermarket methods.
https://www.amazon.com/Baomain-DH-67...mp+meter+shunt
WayneG is offline   Reply With Quote
Old 10-15-2017, 11:32 PM   #3
1972 23' Safari
It looks like a copper strip with a slider for one of the legs. Is it really that simple? What would the gauge and dimensions of that strip be? Any ideas?
-miker
Old 10-16-2017, 05:10 AM   #4
WayneG's Avatar
Scotia , New York
-miker
It would not be copper because the resistance is too low. It would be a strip of resistive metal, thick enough to handle the total load current and long enough to generate millivolts between the 2 sense points. The shunt also needs to keep that resistance stable through a reasonable temperature range for meter accuracy.
This link may be a bit to technical, but it has the basic info.
https://meettechniek.info/instrument...resistors.html
If you are trying to make an exact replica, you are better off finding one in a bone yard. If it were me, I would find a commercial shunt that matches the meters needs.
Ammeter connection bridor15 Batteries, Univolts, Converters & Inverters 8 02-13-2011 07:19 AM
Anyone out there with ammeter/shunt experience? johnobuttons Lights - Interior & Exterior 2 08-17-2009 12:40 AM
Ammeter Vs Ampmeter kennytheecat Electrical - Systems, Generators, Batteries & Solar 16 04-16-2009 01:56 PM
Ammeter need William8979 Electrical - Systems, Generators, Batteries & Solar 1 01-28-2007 08:32 PM
Ammeter smily Electrical - Systems, Generators, Batteries & Solar 14 08-12-2002 10:09 PM
