Originally Posted by Dennis C
Why wouldn’t you use a simple dog bone connector? Would this not work?
I did close to the same thing as OP. To answer your question, my 50A unit has a really heavy and difficult to maneuver power cord. Getting it in and out of the small storage spaces of airstreams is a real pain - especially if all I'm doing is charging batteries. I'm also not a huge fan of chaining my 50->30 dogbone to my 30->15 dogbone and then to an extension cord. Currently, Smart Plug doesn't sell a "ponytail" adapter for their plugs as they are unique - they are apparently still awaiting UL certification on a new design.
My take on it below:
* I bought a medium duty 100ft 15A extension cord from Lowe's.
* Cut the female end of the cord off - leaving about 6-8" of cord attached to it.
* Connect white-white, black-black, ground-green
* Cut off a 3-4" piece of black wire from the piece still attached to the female end.
* Connect this piece between the black and red connectors (solder the two black wires together if you can)
* Assemble the plug per the instructions...
To counteract water intrusion (since the 15A cord is much thinner than the 50A cord the plug and shroud was designed for), I cut a wine cork in half lengthwise and cut a small channel down the middle of each half. I wrapped the 15A cord with some electrical tape where the shroud would normally seal around it (but it won't because the shroud is too big) and I hot glued the two pieces of cork around the 15A cord in that spot. Rubbed some soap around the inside of the shroud and slid it into place when I assembled everything. Now its pretty much water tight.
