06-21-2022, 04:30 AM
2021 30' Globetrotter
Oviedo
How long to leave AGM battery powered rig unplugged?
I know I can add a real disconnect switch or manually pull the the battery wires. That's not what this question is about.
On my 2021 25' GT my flooded cell batteries would start getting very low on charge after about a week (right at 12 V) with the onboard battery disconnect switch turned off. My new 30' GT with AGMs seems to be fairing a bit better than that. So far, I've dropped from 12.9V when I put it in storage to 12.7V. I'd like to feel comfortable leaving it for 2-3 weeks unplugged. Maybe it will stay above 12 V for that long? I do have 15 amp power at storage and up to this point always left it plugged in. But I've had a couple of occasions where I come to check on the trailer or pick something up and the GFI has tripped and I don't know how long it's been without power with the shore power switch on. I do have solar, but it's covered storage so that won't help much.
The previous owner of the 30' kept it plugged in all the time so I assume the batteries are in good condition. Not sure the owner of the 25' was as observant of battery maintenance since he seemed shocked when I asked him what tire pressure he kept it at and he said "I don't know, I've never checked it".
06-21-2022, 05:03 AM
2017 16' Sport
N/A
, N/A
A proper functioning AGM in cooler weather with no load will be fine for at least a month, warmer weather less.
addendum, with the carbon monoxide detector drawing current, I wouldn’t trust it more than a week.
06-22-2022, 01:02 PM
2022 25' Flying Cloud
Western
, Maryland
That’s my conclusion based on my recent experience, especially the addendum
06-22-2022, 01:28 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Like it or not, voltage is not a great way to determine battery state of charge. Your "starting point" could be at 80% or at 100% and you still would have roughly 12.6V on your monitor. Since you stop at 50%, this is a pretty big deal.
Next up, capacity changes with temperature. If it's freezing out, you aren't going to get as many days as if it's 120 degrees in the shade. Temp also impacts the magic battery voltage readings so you may decide the battery is dead when it's still well above 50% ( if it's hot out ....).
Flooded cells ( at least the stock ones ) aren't quite as high quality as the (stock) AGM's. They also need to be checked regularly for fluid level and "topped up". In Florida it is an issue. In Arizona it's a very big issue. If you are used to camping in Nova Scotia and find yourself in Tucson all summer, your battery habits may need to be improved a bit .
All batteries can be damaged. You never quite know how this or that set got treated as part of the delivery process. If the trailer is used, who knows what the PO did or didn't do. The stock AGM's are a bit more tolerant of abuse than the stock flooded, but neither is likely to be happy with a lot of abuse.
One of the (as yet) unmentioned parasitic drains is the inverter (if you have one). Reports area all over the map for power off inverter current drain. Some folks seem to have ones that are really crazy. If yours (like theirs) pulls a quarter amp (yikes !!!) when shut off, that's 6 AH a day. Good luck with your two week plan on that rig. Yes, I'd claim that's a defective inverter ..... who knows ....
Bottom line: If it's parked, plug it in.
06-23-2022, 04:53 AM
Oviedo
Hi
Except my power is unreliable at the storage facility and I assume the draw his higher if the shore power switch is in the "operate" mode and will kill the battery faster. I suppose I'll have to bite the bullet and put in a real disconnect switch. Pulling the terminals off is a bit of a pain the way they have these things wired up.
06-23-2022, 04:58 AM
1994 25' Excella
Waukesha
, Wisconsin
A real disconnect switch is the answer.
And, if you have a shunt battery monitor like the Victron 712, consider putting the disconnect on the negative side of the battery bank. Depending on how they are connected the shunt systems can still pull a small drain on the batteries even with the disconnect on the positive. Mine does it through the combo temp probe/power supply to the shunt which is on the positive side of the battery bank.
Richard
11018
06-23-2022, 11:58 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Parked = sitting at a campsite with folks here and there
Storage = something different than parked
06-25-2022, 05:00 PM
Oviedo
After charging my batteries for 2 says, they seem to top off at 12.9 volts. The trailer sat with the shore power switch off for 10 days and it dropped to 12.7. As uncle Bob pointed out, voltage is not a perfect indicator of state of charge, but for my purposes it looks like I can safely leave it off for 2 weeks with no worries.
06-25-2022, 07:56 PM
2022 28' Pottery Barn
¯\_(ツ)_/¯
Although you said your question is not about a disconnect switch, what Richard said at Post #6 is correct.
Wire yourself a disconnect switch to your negative.
Done.
06-25-2022, 08:23 PM
1969 25' Tradewind
Shasta Lake
Co and smoke detector is on all the time and pulling power regardless of the disconnect switch position.
You will have to disconnect it for long term storage. Reconnect when getting ready to take out of storage .
How you do this is up to you .
But Do Not occupy the trailer without it connected.
06-25-2022, 08:30 PM
¯\_(ツ)_/¯
and don’t drive it while the full disconnect has been switched.
06-25-2022, 09:58 PM
Oviedo
I know what the right answer is. But I’m lazy and have other things going on. Not to mention I’ll bet most people have no idea what this issue is and run their batteries into the ground without even knowing it. I wonder if having the shore power switch on creates more draw than thos parasitic loads from the CO detector assuming you have everything else turned off? If that’s the case, I’d be fine just leaving it plugged in at storage and not worrying about the power going out from a GFI glitch?
Done.
Attachment 418315
06-25-2022, 10:44 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
With the charger connected, a full charge should be up around 13.2 to 13.4 volts. That's measured at the battery terminals *with* a good multimeter. Once you disconnect the charger for an hour or two, they should settle to 12.6 or there about.
All battery "magic voltages" are temperature dependent. They vary by a half volt or more over a fairly normal camping temperature range. The numbers above are for a 70F sort of battery temperature.
If you are looking at the stock battery readout, who knows what you will see. They can easily be off by a a few tenths even with no load. Toss in load and you get another couple tenths.
06-28-2022, 09:19 AM
Oviedo
Sure, 13.2 and up is typically what I get when connected, although sometimes it seems lower when the batteries are topped off.
Hi
06-29-2022, 04:52 PM
2019 30' International
Pennsylvania
, Pennsylvania
My unit is stock, with the lifeline AGM's. When I plug in my 50 amp at home the charge will settle in at 13.6v. (In the garage, no solar)
Somewhere around two days later it'll drop to 13.2, some times 13.1.
I'll unplug the 50 amp cord and shut off the "use/store", er "battery disconnect" switch.
The voltage of the batteries the next day will read 12.9, and will slowly fall over two weeks or so to 12.6/12.5, depending on how much time we spend doing little things in the trailer.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
