RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 12-05-2020, 03:09 PM   #1
dznf0g's Avatar
Oswego , Illinois
Help with Main 12V Breaker spec
I am looking for the sourcing for a main 12V breaker at the positive buss for a 2000s era Classic 30. These are not the breakers at the 12V distribution box.
I decided to clean up some wiring, fix some poor crimps and replace some of the horribly stiff wiring with stranded marine cable. AS tightened one of the nuts on a breaker post so tight that it broke the plastic base of the breaker when loosening. It obviously works no more. I can't see the specs or brand without taking the whole buss off, and I'd rather not do that without new part in hand.
I think they are 30 amp self resetting, but I am not sure. The branch breakers in the distribution box are manual resetting.
Does anyone have that brand, part number and spec?
Thanks much!
Oh! I also found one installed upside down! Copper post goes to the copper buss bar right? The other 4 are installed the way. They aren't bi-directional are they?
-Rich-
Old 12-05-2020, 08:04 PM   #2
DaveP's Avatar
2004 28' Classic
Monument , Colorado
I am doing the same thing you are, but I am replacing all of the short stop fuses with ATO fuses and a SafetyHub 150. I have not yet replaced the fuse you are talking about, but my drawing (2004 Classic) show that it is 50 amps.
I will be replacing mine later this coming week. I'll let you know if it is different.
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 12-06-2020, 07:05 AM   #3
dznf0g's Avatar
Oswego , Illinois
Thanks Dave,
I tore into it last night. Standard ShortStop 12V N10 30A self resetting breaker (sans bracket). Amazon will bring it today.
-Rich-
Old 12-06-2020, 07:24 AM   #4
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Rich,
Got a pic or two, before after and mystery part?
Crimp on!
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 12-06-2020, 07:46 AM   #5
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Rich,
Glad you got it resolved.
DaveP
Old 12-06-2020, 07:57 AM   #6
dznf0g's Avatar
Oswego , Illinois
1st pic is the backside of the buss showing the brand and specs.
2nd pic is the buss front before removal.
3rd shows the wall mounted battery cable protection breakers. I think they are 50A.
The buss breakers are 30s. Click image for larger version
ID:	384374Click image for larger version
ID:	384375Click image for larger version
Note the breaker 3rd from the right....installed upside down. I never noticed it till now.
-Rich-
Old 12-06-2020, 08:04 AM   #7
GCinSC2's Avatar
Rich
I see some mods I don’t have but pic 2 wiring spaghetti looks real familiar.
Gary
S/OS #001
Old 12-06-2020, 08:17 AM   #8
dznf0g's Avatar
Oswego , Illinois
Yes, I have done a few mods over the years. Shunt for monitor, solar install, desulfater, victron battery protect, relocation of components, etc. Its getting crowded in there. No room for Mr. Reactor.
This exercise started with eliminating the battery doors and bringing 2 lifeline gpl 31XT AGMs inside. Click image for larger version
-Rich-
Old 12-06-2020, 08:31 AM   #9
dznf0g's Avatar
Oswego , Illinois
Just a couple more pics that might be worth posting for posterity and visual documentation.
ID:	384383Click image for larger version
ID:	384384Click image for larger version
-Rich-
Old 12-06-2020, 10:57 AM   #10
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Yours looked like mine did three years ago. I liked my set-up, but the Lifeline AGMs take too long to charge. With the steeply discounted lithium prices in November, I decided it was time for more capacity and quicker charging.
Below is a picture from last week before I started tearing out the rats nest and rearranging. BTW, the SafetyHub 150 is really a nice product to replace the Airstream distribution panel! I'll send a final picture when it is done.
Name:	Before Electrical.jpg
DaveP
Old 12-06-2020, 11:25 AM   #11
dznf0g's Avatar
Oswego , Illinois
I wouldn't call that a rat's nest. Sure its not breadboard neat, but that takes away storage space. You have room behind the electrical center for a breadboard. I'd lose my subwoofer it I didn't put a battery back there.
-Rich-
Old 12-06-2020, 11:51 AM   #12
DaveP's Avatar
2004 28' Classic
Monument , Colorado
I am losing the box around the Magnum inverter which will help. I am going to put the SafetyHub in front and to the left of the magnum so it will be easy to access. I am putting in 4 lithium batteries where the current batteries are, so that will take up the same space. I also put in a 20A DC to DC charger, and that is already mounted on the left side couch trim piece. My solar charger is mounted inside the right side couch arm rest. I am trying to neatly bundle all the wires. We'll see how it turns out.
BTW, I lost my battery boxes just like you did (on my original AGM install). Stupid design in the first place. Gave me a lot more room
DaveP
Old 12-06-2020, 12:05 PM   #13
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
If the 50 amp AC breaker is hooked up to your outside pedestal connection, then it is serving as a main breaker and adds safety to your 50 amp power cable. That is why it is wired backwards. The same goes for the 12 volt DC input from the batteries. I believe the lugs on the AC breakers are Torx 20 that makes them a lot easier to tighten correctly.
guskmg
Old 12-06-2020, 03:42 PM   #14
dznf0g's Avatar
Oswego , Illinois
guskmg
These are all 12 volt breakers that I am talking about.
There are 2 (1 on each battery cable) 50 amp breakers. The 2 positive cables attach to the buss bar. The bar has 4 "main breakers". One breaker feeds the distribution panel which has 7 breakers to serve the house. The next buss breaker was originally empty. The next served the jack, charge line from the tow vehicle. The last one serves the hydraulic brake actuator.
It was the one for the charge line and and jack that was upside down.
-Rich-
12v
Replacing the main 30/20 split breaker in our 2014 27FB Rocinante General Repair Forum 22 10-26-2017 11:01 AM
main breaker Dave.hendrix Electrical - Systems, Generators, Batteries & Solar 1 03-12-2015 01:21 PM
Retainer for Back-fed Branch Breaker used as Main Dean E Electrical - Systems, Generators, Batteries & Solar 2 11-08-2013 01:59 PM
main breaker box Grapes Electrical - Systems, Generators, Batteries & Solar 2 04-05-2013 12:53 PM
help with finding main breaker cyberstream Classic Motorhomes 3 08-27-2010 10:01 PM
