07-31-2019, 10:45 AM
2018 25' International
Lewisville
Help w/ easy start
I installed the easy start on my 2018 25 Penguin 2 AC.
Today I hooked up my 3100 watt generator for the learning starts before heading out on a trip next week.
The first (and only) time I turned the AC on there was a godawful noise and vibration coming from the AC. I shut it off.
I just contacted micro air and am waiting for their response.
Anyone have any ideas, or does anyone know of an Easy Start expert in the Dallas Fort Worth area?
Thank you,
Matt & Roxanne
2018 FB Twin INTL Serenity (The Flying Squirrel)
2019 F250 DIESEL (Ferdinand)
@tflyingsquirrel
07-31-2019, 10:58 AM
2013 30' Flying Cloud
Kingwood
Did you pull the cover off of the outside AC unit to inspect it for a possible loose wire that got caught up in the fan or something else that might not have gotten put back in it’s proper place?
07-31-2019, 11:00 AM
2019 30' Classic
Canfield
, Ohio
I would not run it anymore!!
Climb back up and look at your wiring again. I had so many problems installing the last one that I almost gave up. After staring at it forever and then walking away for a while, I came back and saw a problem with my wiring immediately. Yeah I know, its just three wires, but the color codes components can be confusing.
There are some good images of the wiring all in one picture that was helpful to me here on the forum.
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
07-31-2019, 11:03 AM
2019 30' Classic
Canfield
, Ohio
07-31-2019, 12:40 PM
Lewisville
OMG. My apologies to Easy Start! Just found a fist sized mud dobber "nest" on the inside of the "wrong" side of the blower. It was most likely the source of the noise and vibration.
It couldn't be in a worse place. It's going to be a bear to get out of there.
Thanks for all your help,
Matt & Roxanne
@tflyingsquirrel
07-31-2019, 12:43 PM
2002 30' Classic S/O
Melbourne Beach
I think you are supposed to train it on shore power. If you have tried to train it on the generator you may have to go through a reset procedure before training it again.
Al
07-31-2019, 12:47 PM
Rivet Puller
2003 28' Safari S/O
Atlanta Burbs
, Georgia
AL is correct. You should start the AC five times on utility power before performing the generator start sequences.
Here is a link to the instructions for resetting/re-initializing the EastStart.
http://www.micro-air.com/support-doc...Relearning.pdf
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
07-31-2019, 01:54 PM
Lewisville
Me: “Can I use my 3100/2800 generator for the learning starts”?
Micro-Air: “Yes. If you have an economy mode, turn it off so it runs full speed.
Best regards,
Roger”
Matt & Roxanne
@tflyingsquirrel
07-31-2019, 01:56 PM
Melbourne Beach
Best regards,
Roger”
Interesting. That is not what they told me at Salem when I bought mine. My generator never came up in the discussion. Maybe if I had asked.....
Al
07-31-2019, 01:59 PM
Lewisville
Now I need to figure out how to get that blower out of there!
Matt & Roxanne
@tflyingsquirrel
07-31-2019, 02:20 PM
2019 30' Classic
Pleasant Garden
, North Carolina
Just had Easy Starts installed on both of my units while it was at JC. Can't get anyone to respond to an email to let me know if they performed the Relearning process. Is there a way I can determine whether or not they did it?
07-31-2019, 03:21 PM
Oswego
I dont thinks so, but you can repeat it per the link in the above post.
-Rich-
07-31-2019, 03:26 PM
2019 30' Classic
Pleasant Garden
, North Carolina
To be clear, is the relearn process what enables the Easy Start units to work? If the relearn is not performed will it be like not having the units at all and the AC's will work like they are not even installed?
08-01-2019, 08:31 AM
Lewisville
Mud dobbers banished! Learning process completed.
Thanks to all,
Matt & Roxanne
@tflyingsquirrel
08-01-2019, 10:20 AM
The Silver TARDIS
2018 30' Classic
Gray Court
, South Carolina
Read the manual. The first few times you turn on the Easy Start it is in Learning Mode, then it evens out. They work great!
Kevin Short
2018 Classic 30RB Twin -- "The Silver TARDIS"
2014 RAM 2500 Cummins Diesel
BlueOx SwayPro 1506
08-01-2019, 02:09 PM
Electronic Controls OEM
Allentown
, New Jersey
EasyStart Resources
Hi Everyone,
We generally do not monitor forum threads because of resource limitations but do try and reply to support requests within a reasonable time-frame, if we somehow overlooked a support email we do apologize for that!
Please feel free to take a look at our EasyStart Knowledge Bank (Searchable) for wiring diagram, guides etc...
http://www.micro-air.com/knowledgebank
If you have purchased an EasyStart please feel free to supply the order# when submitting a request for Technical Help.
http://www.micro-air.com/microair_support.html
Thanks!
The Micro-Air Team
