Old 07-09-2022, 07:56 AM   #1
Knoxville , Tennessee
Help finding an adapter
Hi there, we recently got a 1974 Landyacht Sovereign.
We took it out for it’s maiden voyage, but ran into an issue when it came time to hook up to shore power. The plug on our trailer didn’t match the 30 amp cord I bought. Any help would be greatly appreciated.
Knox_JDH is offline   Reply With Quote
Old 07-09-2022, 08:22 AM   #2
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Here's a bit of information on what you likely have: https://www.etrailer.com/question-383523.html
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 07-09-2022, 08:49 AM   #3
This is great, thank you so much!
Old 07-10-2022, 07:35 AM   #4
Chelsea , Maine
Unless you’re determined to keep it ‘original’, I would replace the receptacle with the modern version.
2023 Entegra Odyssey 26M
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
JMynes is offline   Reply With Quote
Old 07-10-2022, 09:27 AM   #5
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
We've upgraded to a smart plug which you might consider since you need to replace anyway. Google "Smart Plug RV"
SuperTrouper is offline   Reply With Quote
Old 07-10-2022, 11:21 AM   #6
1973 23' Safari
Germantown , Tennessee
+1 on the Smart Plug. Much sturdier connection.
lojoma is offline   Reply With Quote
Old 07-10-2022, 02:12 PM   #7
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
If you go the SmartPlug route, keep in mind that they are quite expensive compared to the "normal" connector. You will spend that money on the trailer end, on the cord to go to it, and again on any adapters you happen to need. We have one on the van and thus more than a bit of empirical data on this .....
Old 07-10-2022, 02:15 PM   #8
hikingcamera's Avatar
2024 25' Trade Wind
Seattle , Washington
+1
I really like the SmartPlug, especially compared to the fickle threaded Twistlock we had on our last trailer (I could never get it to thread correctly on the first try), but man, even the simple 30-amp to 15-amp shorty adapter was over $150. I hope it means that all the employees involved in production are getting a strong wage and benefits.
hikingcamera is offline   Reply With Quote
Old 07-11-2022, 09:02 AM   #9
Thanks, everyone! I'll look into the SmartPlug option.
Old 07-11-2022, 10:10 AM   #10
After looking into the SmartPlug. I am interested in going down this path. However, I do have some reservations.
The current plug that's in the AS is round and has 3 screws and the SmartPlug is square and has 4 screws. If I get this and start the process, how can I ensure the screws anchor properly? Also, is the wiring in my '74 going to be the same? i.e. have black (hot), white (neutral), and green (ground) wires?
Old 07-11-2022, 12:55 PM   #11
Half a Rivet Short
2022 Interstate 24X
Hi
Anything you replace that original plug with is going to involve a bit of metal work. None of the alternatives will be ideal for the hole you already have.
Wire wise, yes, they all use the same three wires that go to the existing plug.
Old 07-11-2022, 01:08 PM   #12
Hi
Thanks, uncle_bob!
Old 07-11-2022, 02:12 PM   #13
1988 32' Excella
Robbinsville , New Jersey
All the 30 amp ones use the same 3 wires.
Don't get the 50 amp version (unless completely rewiring for 50 amp) it has 4 wires 2 hot, 1 neutral and 1 ground. Also 50 amp requires heavier wire needed to prevent fire burning up your trailer.
Old 07-11-2022, 02:53 PM   #14
Good to know, thanks Wazbro
Jon
8577
1974 31’ Sovereign
Old 07-11-2022, 03:00 PM   #15
2015 25' Flying Cloud
Schaumburg , Illinois
Count me as another fan of the smart plug, I converted my trailer over to that about a year ago. Yes, it is a pricey/expensive change, but the peace of mind is well worth it to me. I have seen several 30A RV power cords with very clear indication of arcing/burning on one contact pin, and I don't want any part of that. Campground electrical can be shaky as it is, I want my side to be as good as I can get it. I ordered my conversion parts as complete kits, they came with the RV side and the cord side as a mated pair, and I needed 2 kits (my trailer has 2 power connection points). I used second cord side plug with a 12awg/20A style cord, for times when a 30A feed is not available. Also no use for 2 of the 30A cords.
1StreamDream is offline   Reply With Quote
62 Sovereign Window Seals- Help Finding Help! 1stTimeOwner Windows, Doors, Locks & Vents 8 02-13-2022 06:36 PM
Help with adapter 50/30 Squirestrhn Electrical - Systems, Generators, Batteries & Solar 7 06-20-2019 11:27 AM
Help! Need help finding inspector in FL. metersixty Buyer Guidelines 1 01-04-2017 06:17 AM
Weird shore power adapter needed help find? Girlfriend Electrical - Systems, Generators, Batteries & Solar 10 10-08-2016 04:22 PM
CO Plug / Strainer Adapter Help rburditt Plumbing - Systems & Fixtures 0 11-10-2008 07:17 PM
