RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 06-16-2018, 07:04 PM   #1
QC TORPEDO's Avatar
2017 25' Flying Cloud
Queen Creek , Arizona
Grounding
It seems from the wiring diagrams for the '17 FC FB that both the 12v and 120v electrical systems use the frame (skin, metal piping) for grounding. Can that be? I need a ground for a lighted switch install for the hot water heater. I can't stand not knowing at a glance that it is on or off. Where do I get a suitable ground?
QC TORPEDO is offline   Reply With Quote
Old 06-16-2018, 08:06 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30 Globetrotter
2014 23' International
Dadeville , Alabama
Frame or skin will work fine for a ground
Old 06-16-2018, 08:25 PM   #3
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Not sure where else it would be possible to ground it, other than the metal skin or metal frame.
Old 06-18-2018, 11:29 AM   #4
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Ok, let's back up a bit. Ground is a protective feature on an AC circuit. Neutral is the power return. On a 12V circuit things can get a bit confused with both protection and return referred to as ground. Protection for *both* should be the chassis of the trailer. It's the thing you are most likely to come in contact with.
If you take a look at a lot of the 12V wiring on a typical AS, they do indeed run red and black for the 12V wiring (to be confusing they also run other colors as well for low current). 12V is bonded to chassis at a couple of locations. 120V normally gets bonded at a single point.
So, 12V is very much like an automobile, with the chassis used a bit less for power return. With most of the trailer made of aluminum, tying things in without corrosion issues is a bit problematic. That drives a lot of the differences.120V. is similar to your house.
Old 06-21-2018, 06:30 PM   #5
2016 30' International
redondo beach , California
I like the idea of a LIGHT on the H2O heater!
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Old 06-21-2018, 07:29 PM   #6
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
All of the 12 volt circuits on my Airstream are 2 wire circuits. I have not seen anything grounded to the chassis as part of the power source. But I guess you could do it to the chassis. I wanted a light on the wh at first but have come to accept the way it works without it now.
Old 06-22-2018, 07:45 AM   #7
Half a Rivet Short
Hi
There are a couple points where they tag to the chassis on my trailer to run it in parallel with a return wire. The jack on the front returns through the frame. I suspect that the power stabilizer jacks do the same thing.
Old 06-22-2018, 08:42 AM   #8
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , NC Highlands County, FL
Your switch can be connected to the trailer skin or frame, to provide a negative path.
People confuse the terms negative and ground. (I am guilty of using the wrong term too)
There is no ground in a 12 volt DC circuit, there is only positive and negative. In our trailers DC positive comes from either the battery's positive or the converter's positive. The negative from both the battery and converter are connected to the trailer's structural metal. So anywhere structural metal is connected continuously it is negative.
There is a ground only in the 120 volt AC system, at times, but not all of the time. There is only a ground if/when the ground wires are connected to the earth. When plugged into shore power there is an earth ground through the ground wires. When plugged into a generator there is no ground, unless the generator is grounded or the trailer in contact with the earth provides ground. (tongue jack, stabilizer jack, plumbing/water, cable TV, etc may provide a path to ground)
The ground wires in the trailer's 120 volt AC system and the negative in the 12 volt DC system just happen to be connected through the trailer's structure, but are not dependent on one another.
Alan
Old 06-22-2018, 10:13 AM   #9
kenen42's Avatar
2011 27' FB Flying Cloud
Delmar , New York
No indicator light bugged me too. Plus I was always turning it on instead of the light since the switches were the same. Replaced mine a couple of weeks ago.
Check the wiring diagram in the manual for your water heater. On mine the negative for the red fault light ties directly to the battery negative, so I used that for my negative connection on the on/off indicator.
kenen42 is offline   Reply With Quote
Old 06-22-2018, 01:28 PM   #10
QC TORPEDO's Avatar
The light on the water heater was pretty easy. I got the lighted switch at an RV supply store. It is rated for 14 - 125v. I replaced the existing switch only. The existing wires go to two points on the new switch as shown on the switch package. The third lug on the switch is for a ground. I picked up a ground from the indicator light on the propane side of the panel. Works great, and now I know.
Grounding Copper gas line slk LP Gas, Piping, Tanks & Regulators 11 06-30-2009 05:33 PM
LED Marker light grounding. briheath Lights - Interior & Exterior 13 05-31-2009 08:33 PM
Electrical grounding problem with AC hook up Mr. D Mechanics Corner - Engines, Transmission & More... 3 09-02-2008 05:20 PM
generator grounding JK3500 Generators & Solar Power 23 06-19-2007 04:59 PM
Proper Grounding of 120V input PhilMateo Electrical - Systems, Generators, Batteries & Solar 24 05-11-2006 08:07 PM
