RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-25-2020, 10:12 PM   #1
2019 27' Globetrotter
San Ramon , California
Green flashing lights behind the sink in the Globetrotter
In my 2019 Globetrotter behind the sink there is a panel with dozens of randomly flashing green lights, does anyone know what this panel is supporting? I ask because that entire panel has gone offline and Iím having all sorts of problems when trying to use shore power but battery support doesnít seem affected.
map372 is offline   Reply With Quote
Old 11-25-2020, 11:25 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
This is likely the control board for your automatic awning. Itís 12v powered.
wulfraat is offline   Reply With Quote
Old 11-26-2020, 08:32 AM   #3
2018 27' Globetrotter
Elbert , CO
Try toggling the power switch on your power awning and see if the board reboots.
djb75 is offline   Reply With Quote
Old 11-26-2020, 08:33 AM   #4
Overkill Specialist
GMFL's Avatar
2020 30í Globetrotter
2014 23' International
Dadeville , Alabama
Correct. It’s the control board for the Awning
Old 11-26-2020, 09:06 PM   #5
Mikebrady62's Avatar
2019 27' International
Rogers , Arkansas
Following
I also agree that it is to support your awning but curious to know what other problems you are having?
When you turn your awning switch back on, did the lights come back ďonlineĒ.
Mikebrady62 is offline   Reply With Quote
Old 11-26-2020, 09:09 PM   #6
2018 25' International
Slidell , Louisiana
Zip Dee hired a sub that liked to provide a lot of diagnostic LED's thus all the flashing lights s. If you could read Zip Dee, you'd know what the board was telling you.
The Zip Dee board unfortunately does not have a good input power conditioner so it is sensitive to out of spec. voltages from the 12V nominal bus. So if you are experiencing battery systems issues, it won't be too surprising to hear the Zip Dee controller has gone offline and may be damaged.....
Brian
Old 11-26-2020, 11:14 PM   #7
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
That is good info. Remember, after powering on the awning, be sure and press closed before anything else. That resets the motors in order for them to work together.
guskmg
LED Tail lights flashing RaymondFitz Lights - Interior & Exterior 24 06-04-2018 10:50 AM
Lights flashing when inverter ON wtdogg Batteries, Univolts, Converters & Inverters 11 10-19-2015 08:14 PM
Flashing inside lights Bbelk General Repair Forum 15 08-29-2013 08:16 PM
Tail Lights: Flashing Slowly/Performing Poorly bgordon Lights - Interior & Exterior 13 09-10-2012 05:11 PM
Flashing marker lights hampstead38 Lights - Interior & Exterior 11 02-11-2009 10:20 AM
