RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 01-16-2020, 11:34 PM   #1
2017 30' International
Box Elder , South Dakota
GFCI circuit and the Inverter
Greetings, this one stumped me for a couple of days so I figured I should share my experience in the hope that it may help someone in the future. Long story sorta short...while on shore power, I had a hair dryer plugged into the GFCI receptacle under the bench in the lounge of my 26RBQ. This is a 20 amp circuit that is also on the Inverter. This specific receptacle has the reset/test button on it and protects all of the receptacles down stream. Well the hair dryer tripped the circuit and we lost power to everything else on the line. However, the GFCI would not reset. The breaker was not tripped, but I had no power to this whole circuit. I figured a bad receptacle and replaced it...still no power.
Well after a few days of trying various things I found a fuse with a rocker switch on the inverter itself. Once I flipped the rocker switch...boom! I had power again.
While I’m glad it was a simple fix, I find it so strange that neither the GFCI, nor the breaker tripped.
Labeda14 is online now   Reply With Quote
Old 01-17-2020, 02:37 AM   #2
Long Island , New York
Good catch.
FYI here are some other mentions of similar situations:
https://www.google.com/search?ei=rHE...4dUDCAo&uact=5
I discovered that rocker switch, in order to turn off our inverter to conserve battery power.
Peter
FYI
FWIW
Microwave Circuit Permanently on Inverter? pteck Electrical - Systems, Generators, Batteries & Solar 18 01-17-2019 11:43 AM
Galley outlet not on inverter circuit geo 2016 - Current International 1 09-09-2018 12:51 PM
Inverter Circuit MissingLink5 Electrical - Systems, Generators, Batteries & Solar 3 07-26-2018 12:57 PM
12v circuit trips shore GFCI AtlasCoffee Batteries, Univolts, Converters & Inverters 15 08-11-2015 05:59 PM
My Trailer Trips the GFCI Circuit - Help? weiss1957 Electrical - Systems, Generators, Batteries & Solar 29 12-30-2008 09:46 PM
