DOHHHHHHT - I found the answer in the first post of the search output you provided: "You only need one plug even if you are using 2 generators in parallel."
But would still be cool if you took a look at the first part of my question about the L530P. :-)
Thanks!
Originally Posted by ROBERT CROSS
Here is a post where Robert@Honda answered my question..
Your adaptor will work.
Thanks for the quick reply,
Bob, but a quick follow-up. I'm confused. You're saying my adapter will work, but, when I checked for continuity between the ground and other two prongs, the circuit was open (for both the L530P and the second adapter with the parallel cables). So, it would appear that my adapter should not work ... ? I don't have the trailer yet and I'm trying to get everything ready for its arrival.
Is it fair to assume that I just need to make an N-G plug? And that plugging this in to either generator's 120v circuit will bond the Neutral-Ground at all generator outputs on both gensets?
Many thanks!
Rich
Save
Save
