[QUOTE=Al and Missy;2402562]Did this work once?
Did you try the switch with the LED removed? Does it still blow the fuse (Actually a circuit breaker).
I did pull the LED from the fixture and tested it in the lamp with no issues.
I pulled the top wire from the switch at the shower and I can keep the other lights in use. That fuse also covers the bathroom light and reading lights in the bedroom. Also the overhead storage in bedroom. It is a 15amp blade fuse on the
12v side. Position number 1
I pulled the fan shroud in the shower to look at the wiring. The dealer replaced that fan for me when I bought it last year as it was not working but it looks like they were not very careful and screwed it in pretty much near the harness. I can't tell if it went into the harness but it was nicked a bit.
I also pulled the panel to access the harness from under the closet next to the shower and I still need to check wiring for trouble coming from lower harness to the switch.
