Old 06-15-2020, 12:57 PM   #1
1972 27' Overlander
Columbus , Ohio
Furrion 30 amp shore power inlet install on 27 foot 1972 Overlander
Hi all,
Does anyone have a picture of where they located the furrion 30 amp inlet on a 1972 back bath overlander, or something comparable? Any tips or suggestion on the install would be greatly appreciated. Thanks!
action95 is offline   Reply With Quote
Old 06-22-2020, 05:06 PM   #2
1960 26' Overlander
South Jordan , Utah
I just installed a black on of these same units on my 60' Overlander. I installed it on the street side about right in the middle. I just enlarged the hole where the previous wire inlet was and then sealed and attached using stainless screws and then caulked all around the seam on the inside of the exterior panel since it is gutted currently.
Robbie_S is offline   Reply With Quote
Old 06-22-2020, 07:59 PM   #3
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
Used the same location as the original, which is towards the rear street side, just inside the rear bath.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Furrion 30 Amp Shore Power Inlet AZORCA Electrical - Systems, Generators, Batteries & Solar 12 01-29-2017 08:34 PM
Furrion 30 Amp Shore Power Inlet vincaroo Electrical - Systems, Generators, Batteries & Solar 15 01-15-2017 06:56 AM
Furrion Stainless Steel 30A inlet and TV inlet Gsmblue Electrical - Systems, Generators, Batteries & Solar 4 07-27-2015 07:58 PM
Furrion 30 Amp 125V Power Smart Inlet Spork Airstream Classifieds 0 04-20-2015 10:32 PM
Furrion 30 AMP power inlet stainless steel svanpelt Airstream Classifieds 0 03-22-2015 02:52 PM
