Old 10-31-2017, 02:58 PM   #1
Rosieriviter's Avatar
2013 25' FB Flying Cloud
2018 30' Classic
Campbellsport , Wisconsin
Furnace issues
When I set thermostat control to heat my air conditioner tuns on with the furnace??
Both run the (AC fan not the compressor ) Outside temp 29 Inside 45. Furnace set on 70. How do I shutdown the AC fan. @2013 FB 25 flying cloud. New to this unit
Rosieriviter is offline   Reply With Quote
Old 10-31-2017, 03:05 PM   #2
DKB_SATX's Avatar
Alamo Heights , Texas
I'm not 100% certain this is the issue you're having, but I'd guess 2 things are going on here. You're probably in "Auto" on the thermostat, with the fan set to be constant-on rather than auto. It doesn't seem like it should do what you're describing at those temps, but it's my first guess.
Make sure the thermostat is set to "FURN" rather than "AUTO" (and check your fan settings) and see if that improves its behavior.
ó David
Zero Gravitas ó 2017 Flying Cloud 26U | WBCCI# 15566
He has all of the virtues I dislike and none of the vices I admire. ó Sir Winston Churchill
Old 10-31-2017, 04:33 PM   #3
Registered User
2016 25' Flying Cloud
Fairfield , California
Adding DKB, you also might have it set on heat pump which Will Not work at that temp. That cold make sure you are on Furnace thus using propane.
Mattirs is offline   Reply With Quote
Old 10-31-2017, 05:09 PM   #4
2018 30' Classic
Thanks for the input. Followed your suggestions. No luck, so I opened the AC breaker, problem solved (for the winter anyway).
Old 10-31-2017, 06:37 PM   #5
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I had this same situation. a few years back. It should be what David said. If the fan speed is set to something other than "Auto", the fan of the AC unit will come on with the furnace. Switch the fan speed to "Auto" and you'll be fine.
2019 Ford Expedition Platinum
Infamous Suburb.NT-22 "recall" furnace issues! fotochop Furnaces, Heaters, Fireplaces & Air Conditioning 7 07-22-2012 07:42 PM
New Member / Furnace issues BigMerc 1974 - 1979 Sovereign 15 10-21-2010 06:04 PM
Wall Furnace issues wolfpack 1960 - 1964 Overlander 0 08-19-2010 06:11 PM
Furnace Issues on 25' Tradewind seeflash Furnaces, Heaters, Fireplaces & Air Conditioning 3 05-16-2009 05:54 AM
'69 AS Sovereign Furnace Issues Engtech05 Furnaces, Heaters, Fireplaces & Air Conditioning 12 03-16-2009 07:23 AM
