Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 04-24-2022, 10:15 AM   #1
Tahoe Vista , California
Exterior step light replacement help
Hi all! I need to replace the exterior step light bulb on our 2010 flying cloud, but can’t figure out how to get the housing off to get to the bulb.
I see there are some dimples on the side of the housing. Do I just use these to pry the housing off?
Thanks!
ID:	414964   Click image for larger version
Double J is offline   Reply With Quote
Step-by-step Vintage Furnace Replacement TomW Furnaces, Heaters, Fireplaces & Air Conditioning 9 11-30-2021 06:56 AM
1992 Exterior Step light can it be repaired? Re-Pete Lights - Interior & Exterior 0 12-11-2020 12:30 PM
'65 Caravel dump valve replacement step by step kevinkatz Waste Systems, Tanks & Totes 9 09-04-2020 11:16 AM
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 795 07-22-2018 10:28 AM
Step by step shell on, front floor replacement '69 Safari thesignlady Repairing/Replacing Floor &/or Frame 31 11-03-2014 11:24 AM
