I recently was getting ready to hit the road... so we fired up the refrig... then went to go get food supplies. Noticed that it was not cold enough.. over night so we turned up the setting to make it so...
Normally the Dometic refrig would go on shore power and start cooling after several hours.
But this time it didn't.. it appears that it started to cool down.. then failed... and the red light was flashing. the refrig was still warm.
What happened was that the 120 volt heater probe failed and so the refrig tried to go on gas.. flashing the red light showing it had failed.
Ok so one would think... no problem ... like a light bulb the heater probe just went out after a few years of use. (we have the big refrig so its a high wattage heater probe)
Nada... after rushing to the RV parts store... and getting a heater probe... installing it... IT still would not work.
Called Airstream .. who said to call Dometic the next day... after a hour we got a tech on the phone.. who said.. 'Well... yep ya probably burnt up the heater probe.. and the refrig was trying to light on gas... (reason for the red light flashing) .
We told him that we put a new one in and it still didn't work... ' Oh he said did you pull the control board and replace it too... ' WHAT!!! ya mean replace the control board.... 'yep he said... sometimes when the element burns up it shorts (which mine did 2.4 ohms on the meter) it takes out the control board by burning up the copper tracing on it. Its all in a service letter that they put out years ago.. he went on to say...
Yep pulled the board.. and sure enough the wiring tracing was burnt off the board.. leaving a black mark where it used to be.
I started looking around on it for fuses... thinking that it surly had blown that too.. nada.. no fuses on the board...
Which brings us to the question .. why... when a 25 cent fuse in line with the heater probe would have saved the circuit board from burning up...
Cheap design... but expensive to replace... as Dometic wants about 300 bux .. when all done... to replace it and the heater probe. This when a 25 cent fuse would have saved it.
When we asked the tech why they didn't design it that way. .he said... we wouldnt be here today if we had... meaning they live on selling their parts... to stay in business... which is understandable.. from a business point but as a consumer... kinda stinks...
So being a engineer... we decided that this shouldn't happen again... (although we bought a aftermarket board... due to new technology and IT HAS FUSES built in .... sweet... )
So the fix is to remove one lead from the 120 v heater probe... from the board.. and put a 3.5 amp fuse in line with it... its a easy fix.. if one uses a push in 1/4 automotive type of fuse... even insulated body too... then you only need to make a Female female... short piece to connect from the fuse back to the terminal on the board... NOW YOU HAVE PROTECTION FOR THE BOARD... and to think it only cost less than a bux...
This wil save the control board if the heater probe ever shorts again.. (which I found happens more often than they just burn open)
I recommend that you take the same action... else it get expensive to replace the shore power temp probe when it shorts out and takes the control board with it... Its easier to buy a new heater probe... and 25 cent fuse.. than 300 bux for the same thing without it..
Note: the new after market board has fuses on them.. both for the 12 and 120 volt line. The dometic tech said that they have added fuses to their revised boards now too... but the early boards do not have ANY fuses to protect them... go figure...
anyone else had this problem ?
