Old 10-25-2021, 07:58 PM   #1
1999 28' Excella
Lake Mary , Florida
EV to RV Cheater plug
I am noticing lots of un-occupied EV charging stations at new gas stations, retail stores and parks. On a cloudy day, my solar needs help, but I do not want to stay at RV park for the night just to recharge my batteries and run the water heater or microwave. Anyone out there know how much amperage you can pull from an EV charging station?
suncoasteng is offline   Reply With Quote
Old 10-25-2021, 08:07 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Here is a good article on that subject:
https://www.rvtravel.com/rv-electric...la-connection/
Richard
Old 10-25-2021, 08:19 PM   #3
Dennis C's Avatar
Evergreen , Colorado
Good article and I agree with the author - trying to power or charge an RV with an electric car charger outlet is a bad idea. I’ve got a NEMA 6-50 outlet in my garage for my electric car charger. It’s 240V, 50A. I can’t imagine what would happen if I tried to connect my Airstream to that outlet, but I know it would be bad!
Dennis
Past:
Airstream International Serenity 23FB
Newmar Ventana 3715
Dennis C is offline   Reply With Quote
Old 10-25-2021, 09:10 PM   #4
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
For what it is worth I installed a NEMA 14-50 outlet in my garage to which I plug in my Tesla charger. It’s the same as any 50A RV service in North America - 2 hot and a neutral.
Agree, a 6-50 240v outlet would be a bad, bad idea as there is no neutral and that is native 240v.
But that’s neither here nor there.
EV commercial level 2 charging stations are not the answer due to their voltage configuration. Just buy yourself a generator if you need an additional charging source and don’t want to plug in at a campground.
wulfraat is offline   Reply With Quote
Old 10-26-2021, 09:31 AM   #5
2017 23' Flying Cloud
Mesquite , Nevada
Most of the EV charging stations at businesses were installed to take advantage of tax credits meant to encourage EV changeover, as such I imagine regulations ban other uses.
Ken G is offline   Reply With Quote
Old 10-26-2021, 09:48 AM   #6
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
Installing a 14-50R with no neutral is a dirty trick. At the very least it should be labeled "Not for RV use" but in reality it should never be wired without a neutral. I have installed dozens of 14-50s for car charging but we always run a full sized neutral and we always label the breaker "EV/RV HOOKUP". Being that there are likely many installations out there where the neutral was skipped I would not risk plugging an RV into one unless you can physically verify that 4 wires were installed. Using a tester is not foolproof as the installer could have ran a jumper from ground to neutral.
PS: here's a product that could turn into a disaster in the hands of an uninformed RVer: https://www.bsaelectronics.com/produ...aided-sleeving
Brian
ITSNO60 is offline   Reply With Quote
Old 10-26-2021, 06:34 PM   #7
wulfraat's Avatar
Mine has a neutral per code.
Old 10-26-2021, 07:04 PM   #8
Dennis C's Avatar
My electrician ran a neutral wire in case of future modification, but the NEMA 6-50 outlet that was recommended for my charger by Jaguar didn’t require it to be connected.
Dennis
Past:
Newmar Ventana 3715
Old 10-26-2021, 07:09 PM   #9
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
There is nowhere to connect a neutral on a 6-50, it is strictly 240 volts. A 14-50 is 240/120 volts.
Brian
Old 10-26-2021, 07:29 PM   #10
wulfraat's Avatar
Yup. Need a 14-50 for a neutral.
Maybe you mean your electrician ran 8/4 or 6/4 line to your box but left the neutral stranded.
Old 10-26-2021, 07:31 PM   #11
Dennis C's Avatar
That’s correct. My apologies for not being clear. The electrician ran the neutral wire to the outlet box, but it’s not connected. If I ever wanted to change the outlet to a NEMA 14-50, the wiring is there to allow it.
Dennis
Past:
Newmar Ventana 3715
Old 10-31-2021, 08:00 PM   #12
2004 22' International CCD
Beaumont , California
You COULD have a transformer on your rig and step down to120 volts; it would be critical to ensure that there is a ground connection from the charger to your trailer frame (if that normally exists). You would connect the 240 volts from the charger to the primary winding on the transformer NOT connecting to the charger neutral.
50 amps at 120 volts is 6,000 volt-amps; quick search only showed 5 kV available, for about $450. You might use an auto-reset breaker rated for 40 amps.
If you do it, let us know how it worked out!
Ndcctrucks is offline   Reply With Quote
Old 11-01-2021, 07:50 AM   #13
1999 28' Excella
Lake Mary , Florida
EV charging
Actually was thinking of 240VAC to 12VDC transformer to charge house batteries, or run 12V systems. 100W transformers are around $20, but that wont run the water pump.
https://www.amazon.com/100-240V-Swit.../dp/B016895YF2
Old 11-01-2021, 09:15 AM   #14
Yeah, 100 watts isn’t going to do much in a short time. You can get more from a solar package.
Cheater vent? hardflanny Waste Systems, Tanks & Totes 0 07-01-2018 08:28 PM
to plug in or to not plug in...that is the questions 4hartungs Batteries, Univolts, Converters & Inverters 39 04-23-2014 03:44 PM
"Cheater Hose" kamadeca Fresh Water Systems 1 07-23-2004 08:16 AM
Trailer plug - Adapter or New Plug?? Jason1101 Brakes & Brake Controllers 4 01-23-2003 05:24 PM
