07-23-2020, 07:42 PM
1990 29' Excella
baltimore
, Maryland
EU2000i starts, imediately dies..
Gas cap is unscrewed.
Fuel pump puts fuel into the bowl.
?Starting fluid seems to have no effect.
New and clean carb.
Unit had not been started in a couple years.
I found a bit of old gas in the tank beforehand.
I poured a small amout of new gas in, swished around and emptied. Did this 2-3 times.
Then before first start attempt, I unscrewed fuel bowl screw and pulled cord til some of the fuel spilled out in attempt to get to fresh gas.
Then start attempts began.
I pulled carb again, but jets were still clear.
07-23-2020, 07:59 PM
CLOUDSPLITTER "Tahawus"
Zanadude Nebula
, Milky Way
Welcome Aboard 👍
Sitting that long with ethanol gas= a carb disassembly and cleaning. e-free gas and StaBil will help.
I have a 2000i dual fuel Honda. e-free Petrol & LP.
Run it on both, drain carb, for storage and keep fresh gas in it. Run it often...no problems in 15 Seasons.
“It’s not the system thats the problem, think Circus, it’s not the car, it’s that the car is full of Clowns.”
John Turley
Tahawus
07-23-2020, 08:35 PM
2019 22' Sport
Port Coquitlam
, British Columbia
^^ What Bob said x2
Running premium gas is a must to keep these little engines running well. Mine gets started up every few months to keep the fuel moving.
Also, I have a BMW electric car with a little generator onboard and it only gets premium (no ethanol gas). Too expensive to fix if the injectors get gummed up with buildup.
I would rather spend my money on Airstream swag
Peter.
"Live Long and Prosper \\//" - Spock
07-23-2020, 08:54 PM
1990 29' Excella
baltimore
, Maryland
Original post says new carb, and disassembled and cleaned before start attempts.
Then jets checked after unit started and quit several times.
07-23-2020, 09:10 PM
2019 22' Sport
Port Coquitlam
, British Columbia
Sorry about that. Looks like you have been working on this for bit trying to get it running.
With the obvious things out of the way, like the fuel is flowing to the carb, Perhaps the cap is not breathing so try loosening it a few turns.
Choke is connected? when the carb was removed and reinstalled did the choke linkage get reinstalled? Try starting without the air cleaner attached.
Main power on/off switch is working?
Spark plug is connected and in good shape?
Did you try priming it with a small squirt of gas right before trying to start it?
That's all I can think of at this point without pulling mine apart. Hope this helps!
Peter.
07-23-2020, 09:26 PM
Long Island
, New York
Try new spark plug, and check wire to plug? How old is this gen?
"Let the Music Lift You Up!"
Peter
07-23-2020, 10:02 PM
1990 29' Excella
baltimore
, Maryland
New coil module. Comes with the plug cap and wire.
I just pulled and observed the spark and to me it looks good.
07-24-2020, 06:37 AM
Zanadude Nebula
, Milky Way
Unplug or replace the in line fuel filter.
John Turley
Tahawus
07-24-2020, 06:39 AM
Long Island
, New York
Bingo -- clogged with debris from old gas?
Peter
07-24-2020, 10:38 AM
2017 25' Flying Cloud
Woodway
Honda EU2000i Quits
There's a pilot jet, top of the carburetor that can get partially or completely plugged. May cause rough, intermittent or no running and it's easily overlooked when the carb is removed for cleaning. Check out this link:
Try this cleaning method outdoors with an ultrasonic cleaner: put your carb in a heavy-duty Ziploc bag and fill enough to cover with ethanol-free gas. Place the bag in the tank's reservoir and fill with water to cover and run about 10 min. That's about all the time the bag will last but that should help clean any passages that might have residual particulates in them.
If you don't have access to a cleaner, use a hypodermic syringe and force 90% or better isopropyl alcohol through the passages. And pay particular attention to the needle and seat in the bowl. If the rubber tip on the needle is indented by the seat, it's time for a new one. Finally, check to make sure the float and needle move freely holding the carb upright.
I did the ultrasonic cleaner on my Honda mower carb after everything else failed. Whatever it was did the trick. Hopefully, the above video will help you get up and running again!
07-24-2020, 10:42 AM
abbotsford
, British Columbia
I had the same issue and took it in to Honda. they had to take it apart and clean the fuel line. The guy said it has a low point where varnish builds up if you leave them sitting too long. He said you should run it every month or 2 to prevent that. I do that, but since it sometimes has to sit for 6 months I bought some Aspen which is a fuel substitute. Aspen is pricey but it works. It does not break down. I fill it with that, run it for awhile and then leave it. When it goes back into regular use I recover as much of the aspen out of it as I can and use regular fuel.
07-24-2020, 10:50 AM
2002 25' Safari
Dewey
My EU1000 was low on oil and had the same symptom. The oil light would come on for a second or less, but it is easy to miss.
Richard
07-24-2020, 11:07 AM
1988 32' Excella
Robbinsville
, New Jersey
This sounds most likely, low oil or unplugged/bad oil level sensor. Mostly since starting fluid made no difference which would mostly eliminate fuel being cause.
07-24-2020, 11:17 AM
2007 31' Classic
Gulf Breeze
Try a little alcohol in the gas tank. Also I had a problem with the same gen. And it was a clogged spark arrestor.
07-24-2020, 11:33 AM
2016 28' International
Trois-Rivieres
, Quebec
Ultimately you could also install a dual fuel (propane/gas) adapter (for example the Hutch Mountain kit) and solve the carburator and bad gas problems by running it on propane (right off your AS or with an extra 20lb tank you could also use for your BBQ). With propane the generator will always stay clean and bone dry when in storage (and it will start!).
2016 International Signature (Oyster/Ebony), Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap, Equalizer hitch
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
07-24-2020, 11:46 AM
2017 27' Flying Cloud
Brookfield
, New Hampshire
My 2000 did this, it turned out there is a recall on the spark plug terminal were it connects to the spark plug. You can temp fix by bending the metal so it contacts the spark plug better. Do a search, there is a thread about it that I started.
07-24-2020, 11:51 AM
1990 29' Excella
baltimore
, Maryland
Ooh thats good stuff.
I will try those things and report back.
If I need a plug, I will probably need to go to the next town over.
07-24-2020, 12:46 PM
Long Island
, New York
Originally Posted by devilsbox
. . . there is a thread about it that I started.
Excellent . . . thanks: https://www.airforums.com/forums/f44...ps-172577.html
Peter
07-24-2020, 02:04 PM
1990 29' Excella
baltimore
, Maryland
Ok, I’m on my way to pick up a new plug.
The one in there is mostly unused, but at leat a year old. NGK CR5HSB. Looks wet from pulling cord.
Oil looked a bit low so I topped it up to almost pouring out. Did nothing.
Now, the unit seems to have degraded. In the beginning, it was firing. Now nothing.
Question. I set the valves. Spec was 0.15mm in and 0.20mm out. Could I have set them wrong? Maybe I reverse them?
07-24-2020, 02:14 PM
1990 29' Excella
baltimore
, Maryland
I disconnected the on off kill wire.
Looked for the oil sensor kill wire.. looks like it might be in deep. Take off the red covers, then there are another set of black covers around the motor. I think its in there?
Is there another connector I should look for? Or wire?
