07-24-2020, 09:27 PM
#41
Just throwing this out there...
Is there any chance that the unit thinks that there is too much electrical load? Not sure how the unit detects and current overload, but maybe if there’s some sort of amp draw sensor that it is going bad?
'21 Caravel 20FB (on order)
TV1: '18 BMW X5 35d
TV2: '15 Tundra Crewmax
07-24-2020, 09:56 PM
#42
1990 29' Excella
baltimore
, Maryland
I did have a fleeting thought along those lines.
Is there a way to disconnect the inverter part of the system and then start the motor?
07-24-2020, 09:58 PM
#43
1990 29' Excella
baltimore
, Maryland
Question:
What if I removed the carb, and tried to start with only starting fluid (which has done zero to date by the way)?
If it ran like this, would that prove its a flooding carb?
Can a carb flood a cylinder in ONE second? Cause thats all I get from this motor
07-24-2020, 10:03 PM
#44
2019 22' Sport
Port Coquitlam
, British Columbia
Originally Posted by groundhogy
Question:
In high school my buddy took my future car (73 Toyota Celica) and ran the fuel line directly into the intake and caught the car on fire and melted a bunch of stuff! Danger Danger!
Peter.
"Live Long and Prosper \\//" - Spock
07-24-2020, 10:06 PM
#45
2002 25' Safari
Dewey
Question:
Two brothers from Ohio flew a plane (Wright Flyer) with an engine without a carburetor. That worked pretty well for them.
Richard
07-24-2020, 10:09 PM
#46
2019 22' Sport
Port Coquitlam
, British Columbia
Was it a Honda?
Peter.
07-25-2020, 12:17 AM
#47
1990 29' Excella
baltimore
, Maryland
Yes..
Maybe a metering issue. Lol
07-25-2020, 07:32 AM
#48
2019 30' Classic
New Milford
, Pennsylvania
Onan generators need the alternator to work to supply power to the ignition system or they have the exact same symptoms as yours does. Mine was a bad diode. Maybe.
07-25-2020, 08:17 AM
#49
Slide Out Society #001
2007 30' Classic S/O
Somewhere
, South Carolina
groundhogy,
I re-read your posts. Timing belt was R&R. Have you rechecked crank-cam timing? If it's off, re set and then adjust valves again. Next confirm compression with compression gauge, cyl "as is" get readings and then with a spoonful of motor oil. Compare the two values. With oil value comes up a bit.
Back to basics on internal components before external components have a chance to work.
Good luck,
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
07-25-2020, 08:49 AM
#50
1994 34' Excella
Warren
, Manitoba
Probably the least frustrating thing to do with this unit is to take it to a competent small engine shop or Honda power products dealer, and let mechanics that know these units repair it. In the end it might even save you money!! JMHO
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
1976 22' Argosy
Hensley Hitch
07-25-2020, 09:48 AM
#51
But that's not fun OR educational.
07-25-2020, 11:07 AM
#52
2002 30' Classic S/O
Melbourne Beach
Get someone to watch the status LEDs when you start it. Maybe one of them is illuminating (low oil, overload). A shop I called (but couldn't get me in for several weeks) told me that most of the time no-start problems are caused by low oil. He said he has fixed not starting units by tilting slightly when filling to ensure a good fill. Maybe when yours starts running it splashes the oil enough to lower below the threshold.
The EU200i service manual is available online. It helped me fix mine. The symptoms were different - hard starting, rough running, then ultimately wouldn't start. IT was the stator coil. There is a winding on it that provides operating voltage for the electronic ignition. If you determine you need a stator, I ended up with an extra.
https://www.google.com/url?sa=t&rct=...mPTXFrLGluvhvQ
07-25-2020, 12:03 PM
#53
1990 29' Excella
baltimore
, Maryland
All I get from this motor is like 1 second of running. And that is once in awhile. It’s sort of like you have to wait a bit before it will fire off again.
-it only runs for a second. Its like the spark goes away with compression... of vibration? Something that happens once motor is active.
-or like a little fumes gets in there after you wait awhile, but thats all it gets
07-25-2020, 02:37 PM
#54
1990 29' Excella
baltimore
, Maryland
Um...
I just put my finger on the exhaust pipe hole...
Pulled the cord a little.
I didn’t feel anything come out.
Is that bad? Lol
07-25-2020, 02:53 PM
#55
Somewhere
, South Carolina
Pull plug, put finger over spark plug hole and repeat test.
Suck Squeeze Pop Phooey
S/OS #001
07-25-2020, 03:24 PM
#56
1990 29' Excella
baltimore
, Maryland
RUNNING !!
Without muffler.
07-25-2020, 04:22 PM
#57
2014 25' Flying Cloud
Cuddebackville
, New York
RUNNING !!
Without muffler.
Probably the only thing that hasn't been mentioned.
2019 Ford Expedition Platinum
07-25-2020, 04:35 PM
#58
1990 29' Excella
baltimore
, Maryland
I think it was mentioned.
07-25-2020, 09:25 PM
#59
1990 29' Excella
baltimore
, Maryland
Well, I want to say thanks to you all for accompanying me and giving me direction during this.
It would have been much harder without you all.
This was actually the end of a complete rebuild of the eu2000i.
There is alot of info out there on repairs to this unit, but I couldnt find anything on an overhaul.
I took pictures and numbered them if anybody is interested. groundhogyh at yahoo
07-26-2020, 04:51 AM
#60
So, was the muffler plugged somehow?
TV1: '18 BMW X5 35d
