RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 07-24-2020, 02:36 PM   #21
Mikebrady62's Avatar
2019 27' International
Rogers , Arkansas
What He Said
Originally Posted by Wazbro View Post
This sounds most likely, low oil or unplugged/bad oil level sensor. Mostly since starting fluid made no difference which would mostly eliminate fuel being cause.
If they are not full of oil or level, you will get those same symptoms.
Mikebrady62 is offline   Reply With Quote
Old 07-24-2020, 02:46 PM   #22
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
Check fuel pick-up in tank.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 07-24-2020, 03:39 PM   #23
1990 29' Excella
baltimore , Maryland
Ok, new spark plug and it immediately trying to fire.
groundhogy is offline   Reply With Quote
Old 07-24-2020, 03:58 PM   #24
1990 29' Excella
Attempting to move fuel tank above so as to gravity feed the carb. Bypassing gas on/off, fuel pump, hoses.
Old 07-24-2020, 04:22 PM   #25
Long Island , New York
Lightbulb
Maybe buy a new Honda 2200?
Have a good weekend.
"Let the Music Lift You Up"
Peter
Old 07-24-2020, 04:56 PM   #26
1990 29' Excella
Riddle me this..
How come starter fluid continues to have no effect?
This seems highly odd.
I changed timing belt and reset valves.
Could I have screwed this up?
Old 07-24-2020, 05:04 PM   #27
dznf0g's Avatar
Oswego , Illinois
Originally Posted by groundhogy View Post
Riddle me this..
Hmmmm, very real possibility. Symptoms fit for valve timing.
-Rich-
Old 07-24-2020, 05:05 PM   #28
dznf0g's Avatar
Oswego , Illinois
Do you have a compression gauge. That would give you a quick idea.
-Rich-
Old 07-24-2020, 05:36 PM   #29
PB_NB's Avatar
2019 22' Sport
Port Coquitlam , British Columbia
Rich, that's a good thought! I have a Ford a while ago and ran into a starting problem when it was very cool. The hotel I was staying at power cycled their outdoor block heater plugs leaving the engine cold.
I went to start it and the extra gas pumped into the cylinders washed the oil off the oil rings and I had very little compression so it wouldn't start. I had to get an oil change to sort that out.
Perhaps a squirt of oil into the spark plug hole might help get the compression up.
Peter.
"Live Long and Prosper \\//" - Spock
PB_NB is online now   Reply With Quote
Old 07-24-2020, 06:43 PM   #30
1990 29' Excella
-checked oil level sensor. Open=oil. Good
-gravity fed fuel tank. No help.
-rechecked valve clearances. They loosened ip a bit.
-checked valves. TDC fire, down, exhaust open, up, intake, down, compress up, TDC fire.
Old 07-24-2020, 06:50 PM   #31
1990 29' Excella
Sticking oil in the spark plug hole..
Old 07-24-2020, 07:00 PM   #32
1990 29' Excella
First pull after resetting valves, put oil in cylinder and it gave a good try at starting. Lol
It sounds sweet for like one second. Then still quitting.
Old 07-24-2020, 07:15 PM   #33
1990 29' Excella
Maybe a hint?
When it does fire off.
I always seem to have to wait awhile before it will want to fire again.
Does that tell you anything?
Old 07-24-2020, 07:36 PM   #34
PB_NB's Avatar
2019 22' Sport
It sounds like fuel starvation.
I think the challenge to resolving this is that these little units just start all the time and are so reliable. Most people don't have any issues with these so the hints are few and far between.
Peter.
Old 07-24-2020, 07:44 PM   #35
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
As above sounds like it is starving for fuel or flooding you said good spark.
You sure the choke is off pull the plug right after it stops and see if plug is wet.
Garry
Old 07-24-2020, 07:57 PM   #36
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
I bet your fuel pickup is fouled at the pick up point in the tank. It is probably terminated with a screen. I had a marine engine that did the same as you are experiencing and found the polyethylene pickup line was collapsed at the end point in the tank and just enough opening to get the carburetor float bowl full which would let the engine run for three or four minutes.
Old 07-24-2020, 08:18 PM   #37
1990 29' Excella
Runs for ONE SECOND
Old 07-24-2020, 08:20 PM   #38
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Another item to check would be the fuel pump. I believe it is vacuum driven.
Richard
azflycaster is online now   Reply With Quote
Old 07-24-2020, 08:22 PM   #39
1990 29' Excella
So what is this wet plug test?
-i put in clean plug
-choke on or off?
-pull cord several times
-remove plug..
Old 07-24-2020, 08:46 PM   #40
1990 29' Excella
I earlier held the fuel tank above the unit direct gravity fed to carb.
Bypassing fuel pump, on/off switch. Some hoses
Honda EU2000I Generator and EU2000I Companion Mldun Airstream Classifieds 0 03-29-2018 11:51 AM
Portable Generator Sound Levels: One Honda EU2000i vs. Two Paralleled Honda EU2000i AndyPenny Generators & Solar Power 19 06-05-2017 04:04 PM
Onan Generator starts, run, then dies JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 19 09-14-2015 06:29 AM
generator starts for second and dies cutbrain Generators & Solar Power 9 08-21-2008 01:22 PM
Attwood heater stinks, then dies! Gasp! Anniedog Water Heaters, Filters & Pumps 0 10-17-2007 08:00 PM
