12-08-2009, 09:48 AM
2010 31' Classic
chesapeake
Electrical Must Haves
What do you recommend, in addition to factory installed, electrical upgrades before you leave the dealer lot?
We are getting a 2010 31d classic, standard factory edition. Boondocking definately in the plan. We want to avoid
going down the road and 20 minutes later wishing we would of????Oh we need ???
12-08-2009, 10:01 AM
Port Orchard
It depends on what model, size, and factory options you order, as well as how you intend to use it.
If you don't order it with a package that includes an inverter, I would recommend having one installed. Look at the boon-docker package, it is pricey, but is nice to have the wiring done.
If you tell us more about what you intend to do, I bet you will get some good suggestions.
Regards,
Ken
12-08-2009, 10:38 AM
1989 34.5' Airstream 345
Cleveland
I think boondocking & solar go hand in hand. Wish I had it.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
12-08-2009, 10:46 AM
1965 17' Caravel
1983 27' Excella
Walnut Grove/Laguna Woods
Ricky
I agree. Solar is not only good for boondocking, but it will keep your batteries at the top while in storage without having to be plugged in. We left our Caravel in storage in June, with batteries full of water and connected to a 55w panel via a good regulator. When we returned the end of September, the batteries were fully charged and still full of water. I would have been concerned leaving the trailer plugged in for that long without attention. I'm sure the batteries would not have stayed full of water. Converters are good, but I don't think they are that good.
12-08-2009, 10:53 AM
Corona
Definitly solar, at least 2 large panels.
Also, not electrical, but balanced running gear.
12-08-2009, 11:33 AM
2023 16' Basecamp
Chgo. N.W. Burb's
Options
Solar !!! Fanatastic Fan's (Auto. Close in case of Rain) Generator in TV.
No Carpet in Trailer. Good Lock's for securing trailer and propane tank's.
12-08-2009, 11:42 AM
Port Orchard
Please tell me you edited your post after my first reply. I hope I am not getting that senile.
We have the same year and model trailer that you are ordering. We ordered it with the factory boondocking package. I don't regret that at all. I am think also of adding a couple of portable solar panels that I can place more oriented to the sun to augment those already installed.
These are some of electrical items that I always carry.
Adapter to allow plugging trailer into normal AC outlet.
Normal AC household extension cord
Extension cord for 12V outlets
Splitter for 12V outlets to allow multiple items to be plugged in.
30 ft extension for the trailer power cord.
Assortment of Automobile type crimp on wire connectors and crimper.
Electrical tape.
I am sure there are more that I am not thinking of right now.
I am planning to buy a whole trailer surge protector before our next trip.
Regards,
Ken
12-08-2009, 01:16 PM
2010 31' Classic
chesapeake
Ken,
No worries, i edited after you posted.
12-08-2009, 01:18 PM
2010 31' Classic
chesapeake
Ken,
What would the inverter be used for and where would it derive its power from?
thanks
clrhflower
12-08-2009, 02:31 PM
Port Orchard
Ken,
thanks
clrhflower
Hi,
An Inverter converts 12V DC to 115V AC. It is wired to the trailer batteries. This allows you to run AC powered devices when the trailer is not plugged into shore power. The boondocker package includes a 600 watt inverter. It is wired to two outlets. One near the TV and one near the door. This allows you to watch TV, etc. while boondocking. The outlet near the door (actually behind a curtain) is in a good place to plug in a laptop power supply while using a laptop on the fold-up table in front of the couch.
Inverters come in a wide range of power ratings depending on your intended uses.
Hope that helps,
Ken
12-08-2009, 03:53 PM
2022 30' Flying Cloud
Phoenix
Always thought I should have an external 12V outlet. Probably add it inside the refrigerator area.
12-08-2009, 05:38 PM
Master of Universe
2008 25' Safari FB SE
Grand Junction
With an inverter you will be using a lot of battery capacity quickly, so if you must have TV, microwave or a toaster while boondocking, consider battery upgrades and maybe more of them. There are numerous battery threads and you will see this is an item that brings out the passions. You can run those items by running a generator if you're jonesing for TV.
Which generator? Many threads on that, but people are happy with the Honda or Yamaha. More watts, more weight. If you need A/C while boondocking, 3,000 watt model (100+ lbs.). Better to go north.
It easier and cheaper to live without TV (radio and CD's still work), microwave and toaster. Solar panel(s) are good to make sure you don't have to run a generator very often and keep the batteries charged while the Airstream is stored without boiling the water out.
Airstream hasn't caught up with the present. You may want a printer for a laptop and will need to make a place for it and run USB cable or go wireless. Wifi someplaces is pretty weak and there are boosters available, aircards for wifi more places. Airstream hasn't figured this out yet—you'll have to go aftermarket.
You may be able to get the 16" wheels as an option which enable you to get LT tires which may be better than the Goodyear Marathons the trailers usually come with. Unfortunately they put Goodyear LT tires on with the 16" option. Those tires are not highly regarded. Maybe you can talk them into picking up Michelin LTX tires in Dayton.
Gene
12-08-2009, 05:45 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
For what?
12-08-2009, 07:14 PM
1999 23' Safari
Perrysburg
, Ann Arbor
External 12v Outlet
Good for lotsa' things, such as working outside in good weather (and 'Streamers only go where there's good weather, right?) with laptop while charging laptop batts. ... or running 12v. compressor for airing tires.
I like the idea, and am getting ready to do some major electrical mods ... may just add this to the list!
12-09-2009, 08:05 AM
Master of Universe
Grand Junction
A compressor that runs off a 12 v. receptacle probably won't pump an Airstream tire very fast if at all. The size of the wire is too small and may blow the fuse. A compressor to fill a 65 psi tire efficiently has to be attached directly to the batteries.
Gene
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Electrical
miljac |
Lights - Interior & Exterior |
0 |
03-23-2009 07:10 PM |
Total Renovation... Must Haves???
oldtrucksrul |
General Interior Topics |
5 |
03-08-2008 07:02 PM |
New electrical need help
BB 55 Bubble |
9 |
10-14-2007 09:57 PM |
Electrical? Uh oh...
PWRSTRK |
4 |
04-23-2006 07:37 AM |
electrical
kent osborn |
1966 - 1968 Safari |
13 |
05-08-2005 08:09 AM |
