RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-27-2020, 10:04 AM   #1
2004 25' Classic
Hanahan , South Carolina
Easy Start question
Hello,
My 2004 Classic 25í with a 13,500 domestic will run on my Wen 2000 generator. I performed a short test but donít want to damage it.
I removed the cover while painting the roof with Bus Kote hoping the previous owner had already installed an easy start but I donít see one.
Can you give me some basics of where to mount the easy start and where I should connect the wires?
ID:	381955   Click image for larger version
ID:	381957   Click image for larger version
Planenut is offline   Reply With Quote
Old 10-27-2020, 10:14 AM   #2
2019 25' Flying Cloud
Houston , Texas
Download the EasyStart Installation Guide. It's quite well done. https://www.microair.net/products/ea...r-conditioners
DCPAS is offline   Reply With Quote
Old 10-27-2020, 10:48 AM   #3
2004 25' Classic
Will I need the generator bonding plug for $18.?? Dollars ?
Old 10-27-2020, 11:01 AM   #4
2004 25' Classic
Also and hopefully last couple questions.
Why would the Yellow wire be cut and capped off? And
Why is the white wire so long and tied in a knot?
PS: I ordered the easy start and the rooftop install kit.
Old 10-27-2020, 11:51 AM   #5
KK4YZ's Avatar
2020 28' Flying Cloud
2017 23' Flying Cloud
Hiawassee , Georgia
My WEN generators do not couple the gnd and neutral inside. If yours is the same, you will also need a bonding plug. To do it right youíll also need a grounding rod. You do this so the chassis of the trailer doesnít float and provide nasty little shocks when you grab the door handle 😀
KK4YZ is offline   Reply With Quote
Old 10-27-2020, 12:40 PM   #6
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
The easy start unit can be mounted wherever there is room. I queried them on locatiion in 2017 and they had changed over to a waterproof box so it can be mounted outside the electrical box.
Name:	Coleman Mach 8 EasyStart 364 Mounting Location.jpg
The photo is for a Coleman, but I assume you have similar open areas.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 10-27-2020, 01:16 PM   #7
SailorSam205's Avatar
South East , Michigan
I'm going to trust Mike Sokol about needing a grounding rod. According to him, you don't need one. That and I can't see pounding an 8 foot rod into the ground at every camp site.
https://www.rvtravel.com/rv-electric...unding-part-2/
Also, you can make your own neutral bond plug for under $5. Lots of instructions on making one on the web.
Al
2017 29' SOB, 2019 Platinum F-150 SCrew, ProPride
SailorSam205 is offline   Reply With Quote
Old 10-27-2020, 01:42 PM   #8
Is it January yet?
jaybauman's Avatar
2019 30' Flying Cloud
Katy , Texas
Don't use a grounding rod.
Build your own bonding plug. I spent $4.99 on mine.
2019 Flying Cloud 30FBB
Bunkhouse is sold...something more "classical" on order!
2020 GMC 3500HD Duramax AT4
ProPride 3P w/ 1400 lb. spring bars
jaybauman is online now   Reply With Quote
Old 10-29-2020, 08:58 AM   #9
KK4YZ's Avatar
Hiawassee , Georgia
How about a 6’ rod? �� Actually you should re-read the article. He talks about campground power utilizing a ground rod to protect you from hot skin stray voltage. When you’re using a generator you’re not connected to campground power. Then you what keeps the trailer chassis potential from floating high (hot skin)? Nothing.
It’s true that you don’t need a ground rod for everything to work. It’s also true that ground impedance is relatively high, but with ground currents being very small it doesn’t take much to pull the trailer chassis to ground potential or close. Also your trailer chassis could be grounded through the jack post if not on plastic or wood blocks.
In my opinion lack of a ground rod doesn’t present a hazardous condition because of ground impedance involved, but you could experience a little momentary bite as you complete the path to ground through your body.
How EASY to break into Airstream? TOO EASY Foiled Again Doors & Locks 24 09-18-2019 09:12 AM
Soft Start - Easy Start - Smart Start..? JConsroe Generators & Solar Power 13 06-16-2017 08:36 AM
Easy-Start Install kit Bob662 General Repair Forum 10 04-30-2017 08:44 PM
