Old 07-24-2019, 08:52 AM   #1
2019 27' Globetrotter
Missouri Valley , Iowa
Easy Start
This may be a stupid question but -- Will an Easy Start allow you to run the A/C on 20 A shore power ?? I did some searching but didn't find an answer. Thanks.
Dan
Farmer Dan is offline   Reply With Quote
Old 07-24-2019, 09:05 AM   #2
Wconley's Avatar
2018 28' International
Renton , Washington
Not the definitive answer but I have run my 13,500 BTU AC from a 20 amp garage plug. You should contact the folks at Micro-Air directly. I’ve found them to be extremely helpful.
Walt
2018 28 International Serenity
2013 F150 Ecoboost
Wconley is offline   Reply With Quote
Old 07-24-2019, 09:06 AM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
The Easy Start lowers the power surge for starting the compressor. It does nothing to reduce the run current of the AC after it is going.
Whether or not you can run the AC on 20 amp circuit depends upon your AC and the quality of the 20 amp service. Our AC does run on 20 amps. I turn off the power converter, put the fridge on propane, and set the AC to full cold so the compressor does not have to restart once it gets going. I monitor the voltage with a little plug in meter to be sure I have enough. I also run the AC on my 2000 Honda generator. I do have the Easy Start. I think the killer for the AC would be if the current switches off and back on quickly. Better to go through the EMS. Note to self: plug the EMS into the 20 amp circuit with an adaptor if I run the AC from a campground 20.
Old 07-24-2019, 09:25 AM   #4
turk123's Avatar
2019 30' Classic
Sunnyvale , California
The AC pulls about 49 amps for a fraction of a second without the easy start. With the easy start, it pulls 16 amps and then settles down to 12 or a little less amps.
Also, if running on 30 amps, it is possible to run both AC's even though one AC does not have an easy start. I've done this many times with no issues. This includes running the fridge and Adle system on propane.
There is a possibility that both AC's could have their compressors come on at the same time, but the chances of that happening are almost impossible as the energy spike is so short.
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
turk123 is offline   Reply With Quote
Old 07-24-2019, 09:25 AM   #5
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
The answer is indeed Yes, if you don't try to run other stuff too. Many of us installed the Easy Start, initially, so that we could run A/C off of 2K generators. But you do not have room for other stuff on the same circuit so run everything that you can on propane and don't do it if the battery is charge is in its early stage.
Larry
lsbrodsky is offline   Reply With Quote
Old 07-24-2019, 09:34 AM   #6
Thank you all for the answers. I suspected you could do this. I think a few years ago I even did it with another trailer and no problems. We do have good electric service here at home. And Bill M - I do run all my RV power through the 50 A surge protector. Thanks for a good reminder on that point.
Dan
Old 08-02-2019, 04:36 PM   #7
2016 30' Classic
DRAPER , Utah
The 2020 International rally is in Colorado and the early information says that only 20A electrical service will be provided. This is making us question if we want to go since it can be hot and no A/C at night could be tough. Thanks to this conversation I'm rethinking. So to be clear, if I get an Easy Start installed on our 2016 30' Classic and run only one A/C we should be good to go, right?
utcruzin is offline   Reply With Quote
Old 08-02-2019, 04:44 PM   #8
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Correct. I just had an Easy Start installed at the International Rally in Doswell. I can now run one A/C from a 20 amp receptacle in my garage.
Soft Start - Easy Start - Smart Start..? JConsroe Generators & Solar Power 14 01-20-2023 04:44 PM
How EASY to break into Airstream? TOO EASY Foiled Again Doors & Locks 24 09-18-2019 08:12 AM
Easy-Start Install kit Bob662 General Repair Forum 10 04-30-2017 07:44 PM
