Old 07-23-2021, 02:01 PM   #1
2021 27' Globetrotter
Malibu , California
Dual AC Performance on hot days
I have a 2021 Globetrotter 27F, dual AC and hooked up to 50Amp.
Boulder, CO:
95'F High / 20% Humidity
70'F Low (midnight)
Airstream:
Inside: 75.4'F / 27.2% Humidity
Both AC's were running full-speed since approximately 8am and set at 68'F, right now at 2pm I measure 75.4'F inside (I have a separate Wifi thermometer for when I leave the dog).
Awnings are retracted (because I am away), all blinds/skylights closed.
Wondering if others get a similar performance?
CMHM is offline   Reply With Quote
Old 07-25-2021, 06:40 PM   #2
kidjedi's Avatar
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver , Colorado
2pm is the hottest part of the day in Colorado, so that's pretty good. If parking in the shade is an option, it will be a night and day difference (pretty literally). Painting your roof white, and better yet using a ceramic IR reflective paint can lower your interior temp by 20 degrees. By that I mean if no a/c was running, the white roof would drop the interior temp that much, thus your A/C would be working much less hard).
p.s. Setting your a/c to 68 does not mean it will cool more; it just means it has to hit a completely unrealistic number before it will cycle on and off. It would be better to set the temp around 75, so that if it actually gets that low it can take a break.
kidjedi is offline   Reply With Quote
Old 07-25-2021, 07:20 PM   #3
2018 30' Flying Cloud
Springfield , Ohio
I believe all Airstream trailers leave the factory with white painted roofs and that has been true for quite some time. They are painted white for the reason stated above - white reflects heat from the sun better than any other color.
2018 Flying Cloud 30RB + 2020 Silverado 2500HD Duramax/Allison
tbrowne is offline   Reply With Quote
Old 07-25-2021, 07:43 PM   #4
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
As others have already mentioned. It isn’t the outside temperature as much as direct sunlight. If the inside wall of your trailer is hot to the touch, it creates a ton of radiant heat. Shade or awnings is your best friend when combating the heat.
- Stewart
s1000pre is offline   Reply With Quote
Old 07-25-2021, 07:46 PM   #5
2021 25' Globetrotter
Oviedo , Florida
I was torn between a 28’ Serenity with a single AC and a 25’ Globetrotter with Dual ACs. When we’re parked at the beach here in Florida 92 degrees without a lick of shade I’ll be appreciating the 75 or lower my 2 ACs will keep my GT during the day. Airstreams have many great points, but insulation isn’t one of them.
jondrew55 is offline   Reply With Quote
Old 07-25-2021, 07:50 PM   #6
Acheron2010's Avatar
2019 26' Flying Cloud
Morristown , Tennessee
Opening that front window shield takes some of the contact heat away from the trailer. I also keep my awnings in if I have to be away. A small fan on the floor helps, also, open the high cabinet doors on the west side. One AC running in my 26 has been enough - ymmv
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
Acheron2010 is offline   Reply With Quote
Old 07-25-2021, 08:41 PM   #7
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Boulder, CO:
70'F Low (midnight)
Airstream:
Gonna be a hot week ahead. I will be working out of my 30’ airstream at pleasant view soccer fields in north boulder this week with a single AC running off small genset + batteries.
Hoping to hold 80 if it’s 91 out. Will deploy awnings. We shall see… will report back
wulfraat is offline   Reply With Quote
Old 07-25-2021, 09:06 PM   #8
Malibu , California
You’re in Boulder?? Oh man I could’ve invited for beer and Microair install
Old 07-25-2021, 10:09 PM   #9
wulfraat's Avatar
Microair + airstream + beer = good.
Old 07-25-2021, 10:29 PM   #10
Malibu , California
Sent you a PM
Hot hot hot aluminum! 58cruzer General Repair Forum 23 06-24-2013 01:08 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
About the "High Performance" dual cams... SteveH Hitches, Couplers & Balls 8 05-20-2010 01:38 PM
Dual Gray Water & Dual Black Water? nvestysly Waste Systems, Tanks & Totes 5 05-09-2003 05:40 AM
