Old 09-25-2021, 06:19 PM   #1
2006 25' International CCD
Lake Jackson , Texas
Dometic Low Profile AC/Heat Pump
Please assist. My AC is releasing an ammonia smell.
MFG# 651815C751C0
Product # 936002276
Has this been upgraded to a new number and if so, which one do I need to order. Iím on the road now and would prefer the least expensive route. Any links for an in stock item that would work would be of great assistance. Need one ASAP.
Iím currently in Louisiana heading to Texas.
Thank you!
Philogod is offline   Reply With Quote
Old 09-25-2021, 06:37 PM   #2
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Isnít ammonia associated with the absorption type fridge? Can you look for stains on the outside of the fridge look for yellow too.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is online now   Reply With Quote
Old 09-26-2021, 08:45 AM   #3
You may be correct. I woke up at 2:00 AM and I noticed my check light on on the fridge panel. Not sure how long it’s been on. I reset it and turned back on the AC and I’m not smelling it anymore. I was wondering why I’d smell any gas fumes if it’s a sealed unit but it sure did smell bad from the AC. Hopefully it was the fridge doing something wacky. Everything seems fine for now. Thank you!
2014 Dometic 15,000 BTU low-profile unit westernjeep401 Airstream Classifieds 0 10-13-2015 05:20 AM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 02:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
Dometic 13500 Penguin low profile A/C unit TinyTin General Repair Forum 0 01-20-2014 09:19 PM
