Hi All,
Just back from our first trip of the season with 2 issues, one I'll walk thru here, the other is a water pump issue so i'll defer that to another post. AS is a 2021 25' FC FB. While on our trip I tried to run the dometic in heat pump mode with our Honda 2200 generator; that dometic unit has a soft start on it and using the 15/20 amp plug on genny. After about 7 minutes the E7 code on Dometic popped, HP shut down, and overload light on the genny turn on while it keep running (sounded like in ECO mode). did it multiple times.
Did not do this in cooling mode though.
One thing I noticed was that I had pulled the 50amp cord as I moved the genny to a further location from the AS 50amp Smart Plug. Upon inspection I see some very mild signs of arcing on both the smart plug and the power cord receptacle, both on the one prong/receptacle that was probably pulled slightly out of being fully seated as I moved the cord.
Here is a pic of the smart plug arcing:
When I got home i tried the HP (in HP and cool mode) on shore power (30 amp) with no issues. Tried the genny again and same issue even with plug properly installed. Genny worked fine on cooling mode.
Unfortunately I also realized I don't have the owners manual for the dometic AC unit, so need to go look up operating specs. Maybe the HP is drawing more power and the arcing damage is just enough to trip the genny in HP, but not on 30amp SP?
So, thoughts on whether the minor arcing is what is tripping the genny into overload? If so, why not on short power (30 amp).
Can minor arcing damage to the AS smart plug be repaired? Lightly file down the damage or something similar?
If not I just made a $365 50 amp 30' pwr cord mistake and whatever a new Smart Plug costs!
Greg
