2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
I only have 30 amp and 1 A/C, but every time I have gotten an E-7 it is simply because my main 30 amp fuse has popped. I cannot run the induction burner if the A/C is on and the water heater and refrigerator are on electric. Normally I remember to turn the water heater off before making morning coffee but get only about 5 seconds after hitting start on the burner to say, oh crud... and reset the alarm clock.
Assuming you are not at a campground with truly awful voltage <109v......
If resetting breakers and ccc2 unit do not correct the issue it’s very likely you have a an issue with a physical/mechanical connection either in the junction box in the ceiling (need to remove return registers to investigate - I believe there is a connection made below the intake) or at the main board outside in the AC itself (need to remove the shroud to access the main board)
Check those out quickly as a next step.
PS - also check the physical connection of the wiring at the breaker itself in your panel.
If you have a 50amp plug (which you certainly do if you have two ACs), it is possible that your campground pedestal may be dead on one leg.
Try using a 50-30 dogbone, plugging into the 30amp side, and then trying only the ac that hasn't been working. If it now works, then you know the problem is with the pedestal.
Pat
Somebody, please, point me to the road.
